Thread: Low Beams don't work but high beams do
Results 1 to 9 of 9
  1. #1 Low Beams don't work but high beams do
    GT Level Member Pursell1911's Avatar
    Jan 2017
    Louisville, Kentucky
    2006 Grand Prix GT
    So out of nowhere my low beams stopped working, both at the same time.
    Here's what I've done so far.
    1. Verify that the low beam bulbs were not broken (I'm assuming this is the same as a regular light bulb?) The filament was not broken inside?
    2. Replaced the headlight relay in the fusebox
    3. Check to see if any wiring was cut, etc.
    What should I check next?
    Matt
    2006 Grand Prix GT - 3" Downpipe | DIY Intake
  2. #2 Re: Low Beams don't work but high beams do
    St. Louis
  3. #3 Re: Low Beams don't work but high beams do
    Jan 2017
    Thanks FordMan
  4. #4 Re: Low Beams don't work but high beams do
    Jul 2018
    TEast ennessee
    I had the same issue, I had to replace the turn signal stalk/switch
  5. #5 Re: Low Beams don't work but high beams do
    Jan 2017
    Was that easy to do? I think that's what I may need to do as nothing I've done has restored functionality.
  6. #6 Re: Low Beams don't work but high beams do
    Jul 2018
    TEast ennessee
    The hardest part is the torex screw that is a PIA to get to. Once you get the plastic molding off the wheel it is not that bad.
    You DO NOT have to remove parts of the dash like in some videos on youtube the cover can be pried apart and put back with using those plastic molding tools made for removing door panels. Once its off it is two screws and a plug.
  7. #7 Re: Low Beams don't work but high beams do
    Jan 2017
    Well thankfully I won't need to do this as the lights started working again. I was working on it yesterday and I replaced a busted turn signal light. I then turned my attention back to the low beams and just moved the wires around, and for some reason or another when I was putting the bulbs back into the housing they started working again. No clue...
  8. #8 Re: Low Beams don't work but high beams do
    Jan 2017
    and they stopped working again...Not at this same time though. Right one went out, then the left one went out maybe 5 or 10 minutes later.
  9. #9 Re: Low Beams don't work but high beams do
    GTX Level Member cheatah faheatah's Avatar
    May 2016
    Rouge Island
    Quote Originally Posted by Pursell1911 View Post
    = Haunted ? lol.
    For the record : I am NOT a naked meth-head who shoves rocks up my butt.
  1. 99 GTP High Beams dont work correctly
    By degarris in forum General Grand Prix Discussion
    Last Post: 12-23-2015, 02:12 PM
  2. Headlights/interior lights go out, work fine with high beams
    By jasonnovak in forum General Tech Discussion
    Last Post: 10-24-2015, 01:39 AM
  3. 05 gtp lows beams stay on with high beams.
    By pontiacGTP123 in forum General Tech Discussion
    Last Post: 06-15-2014, 01:24 PM
  4. My DRLs & Low Beams Are not working, high beam work
    By FlaminWhite97GTP in forum Audio, Security & Visual Electronics
    Last Post: 01-18-2010, 01:26 PM
  5. No High Beams
    By taximech in forum General Tech Discussion
    Last Post: 06-23-2009, 11:37 AM
