Thread: 2007 Pontiac Grand Prix Heated Seats (Can anyone program my BCM?)
Results 1 to 7 of 7
  1. #1 2007 Pontiac Grand Prix Heated Seats (Can anyone program my BCM?)
    Jul 2018
    Macomb, MI
    Hello, I am new to this forum and was hoping to find answers here since my local dealerships seem to be clueless! I just picked up a 2007 Pontiac Grand Prix base with cloth seats blahblahblah. I bought a set of leather seats out of a donor car at the junk yard along with the new HVAC panel with the heated seat buttons and went to plug everything in and realized the passenger harness was different. Did some research and found that the seats came out of a 2005 and the difference was the airbag connector for the pressure sensors in the seats, so I took the seats back and they gladly exchanged the seats for a leather set out of a 2007. Plugs fit perfectly, plugged them in bolted them down, plugged in the HVAC module and thought I was good to go, you press the heated seat button and it just blinks as you push it then shuts off, I left the battery disconnected overnight, nothing. Thinking it was the module I switched out the HVAC module for a different one, no luck, same issue. I called the dealership to see if maybe it was something they had to program to the BCM to tell the car, okay you have heated seats now, turn those puppies on. They all tell me no they should be plug and go. Just out of curiosity because It's been driving me crazy I bought a body control module for $10 out of a salvage grand prix with heated seats at the junk yard and plugged it in, the heated seats work! low and high, BUT now the car wont start and the radio is locked and all that good stuff. So, obviously what the dealership is telling me is not in fact true, I do need to somehow reprogram the BCM, I know since dealerships can be clueless sometimes and charge rediculous pricing from experience with my last car a BMW, there was a guy on a forum I met that would send you out a cable, you plug a laptop in and connect to wifi and he could change whatever settings you wanted over the phone. Does anybody on here offer that? Thanks for any tips or input!
  2. #2 Re: 2007 Pontiac Grand Prix Heated Seats (Can anyone program my BCM?)
    May 2012
    lebanon ohio
    I have the same car and have done leather swap as you. You do have to get the bcm programmed to get heated seats to work. And dealer or someone with tech2 is the only way it is going to work. I just never messed with it.
  3. #3 Re: 2007 Pontiac Grand Prix Heated Seats (Can anyone program my BCM?)
    Never Never Land
    Out of curiosity where is the BCM in this body style?
  4. #4 Re: 2007 Pontiac Grand Prix Heated Seats (Can anyone program my BCM?)
    May 2012
    lebanon ohio
    Drivers side of dash take side cover off you will see it mounted to bottom dash panel.
  5. #5 Re: 2007 Pontiac Grand Prix Heated Seats (Can anyone program my BCM?)
    May 2016
    Burns City, Indiana
    You cannot swap bcm from car to car, all modules must be programmed to the car and as far as i know they can't be reprogrammed to second car. Never tore bcm down and only had limited time using tech 1 never got to play with tech 2 at dealer. In familiar with software and interfaces. Supposedly vxdiag has a emulator that uses gm software. You can get them off Amazon. They will flash OEM pcm but don't let you tune as far as I know.
  6. #6 Re: 2007 Pontiac Grand Prix Heated Seats (Can anyone program my BCM?)
    Never Never Land
    That VXdiag looks interesting. I’d like to give it a shot. The BCM in my GXP was replaced but wasn’t programmed for heated seats and it also wasn’t programmed to match the SDM module
  7. #7 Re: 2007 Pontiac Grand Prix Heated Seats (Can anyone program my BCM?)
    GTX Level Member wstefan20's Avatar
    Aug 2017
    Raytown, MO
    First hand experience, even if you have access to VXdiag or tech2, you still need acess to gm's database in order to flash bcms. I looked into this since my friend has a tech2, and it's more expensive than having the dealer program it just to access gm's system for one day.
    I have swapped these seats in my 02 gp, and had to do some custom wiring and swap from some older heated seats, but you can get both to work of just a toggle switch. Won't say it's easy, but it works.
  1. Climate Control Lights - 2004 Grand Prix GT2 with heated seats
    By Michigan04GrandPrix in forum Audio, Security & Visual Electronics
    Last Post: 01-24-2016, 03:03 PM
  2. 2007 pontiac grand prix gt axles
    By shadegt in forum General Grand Prix Discussion
    Last Post: 05-18-2015, 11:26 AM
  3. 2007 Pontiac Grand Prix GT Intake
    By gemajesse in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-06-2015, 12:43 PM
  4. Replies: 3
    Last Post: 03-01-2013, 08:37 PM
  5. 1998 Grand Prix Heated Seats Wont Turn Off
    By njfelix0712 in forum General Tech Discussion
    Last Post: 02-19-2011, 09:35 PM
