Changed plugs wires and had it scanned comes up cam sensor no missfires but really hard to start cold or warm please help why???
Usually fuel related. Check fuel pressure.
Fuel pressure is 59 with key on and 66-68 running...will only start now if hold gas about 1/4 throttle sputters for a sec clears out n rins fine then untill shut off and starts all over agian
Have you tried cleaning the tb?
Dirty TB is really common, the TPS sensor doesn't like when the blade hits a few microns of carbon before it reaches the full closed position and it'll snap the blade to fully shut and kill the engine.
It's retarded like that. IDK why.
Yes cleaned the tb also just replaced cam sensor witch what code it set pulled bat cables for about 30 mins checked wire harness all good and after 10 mins of running set same code agian and only way to start it is cycle key couple times and hold gas about half way rhen will start n run fine...totaly lost....
