Thread: 05 gtp
Results 1 to 6 of 6
  1. #1 05 gtp
    Jun 2018
    WI (Wisconsin)
    Changed plugs wires and had it scanned comes up cam sensor no missfires but really hard to start cold or warm please help why???
  2. #2 Re: 05 gtp
    May 2008
    Schuyler, NE
    Usually fuel related. Check fuel pressure.
  3. #3 Re: 05 gtp
    Jun 2018
    WI (Wisconsin)
    Fuel pressure is 59 with key on and 66-68 running...will only start now if hold gas about 1/4 throttle sputters for a sec clears out n rins fine then untill shut off and starts all over agian
  4. #4 Re: 05 gtp
    May 2008
    Schuyler, NE
    Have you tried cleaning the tb?
  5. #5 Re: 05 gtp
    I break things. WarStryker13's Avatar
    Oct 2014
    Frederick, MD
    Dirty TB is really common, the TPS sensor doesn't like when the blade hits a few microns of carbon before it reaches the full closed position and it'll snap the blade to fully shut and kill the engine.
    It's retarded like that. IDK why.
    04 GP GT2: Handling upgrades, go-slow parts, and an attitude. Totaled.
    87 Dodge Ram 50:​ Junkyard rescue, resurrection in progress.
  6. #6 Re: 05 gtp
    Jun 2018
    WI (Wisconsin)
    Yes cleaned the tb also just replaced cam sensor witch what code it set pulled bat cables for about 30 mins checked wire harness all good and after 10 mins of running set same code agian and only way to start it is cycle key couple times and hold gas about half way rhen will start n run fine...totaly lost....
