I just started using the air conditioner for the first time this season and I am noticing that my car tends to run hot. The gauge never gets in the red but gets up to the line before it. Is this normal for this model car? I have recently had the water pump replaced and had issues with my heat so I have had the heater core flushed on two seperate occasions as well. Could this be a symptom of a faulty thermostat? I checked the overflow resovoir for the antifreeze and it appeared to be normal.I should mention that this only happens when idling in traffic. As soon as I start driving the fans kick in and the gauge goes down but then immediately go back up as soon as Im stopped. Just wanted to bounce this off you guys.
John
