Thread: 2008 Grand Prix V6 Fuel Issue
Results 1 to 3 of 3
  1. #1 2008 Grand Prix V6 Fuel Issue
    May 2018
    Texoma
    At the fuel rail, I barely have any fuel pressure and it will not start until I cycle the key several time, allowing the fuel pump to cycle. Then I test the fuel pressure at the rail and it has pressure and it will start without an issue. If it sits over night, same thing. Replaced the fuel pump thinking that would fix the problem, it did not. Car drives fine, doesn't stall or hesitate. No codes shown. I'm at a loss for what the issue might be.
  2. #2 Re: 2008 Grand Prix V6 Fuel Issue
    St. Louis
    When you replaced the fuel pump, did you replace the entire canister/pump assembly or just the pump itself? If just the pump check the corrugated pipe that goes from the fuel pump to the line that feeds the motor. Might not be tight and loosing pressure. Also, when you first turn the key do you wait for the fuel pump to stop running it's prime or do you just roll the key straight to start? That will have an affect to. I noticed mine fires up quicker if I let the pump do it's thing at the key turn and then turn it to fire it up.
  3. #3 Re: 2008 Grand Prix V6 Fuel Issue
    May 2018
    Texoma
    replaced entire canister and yes, I let the fuel pump finish its cycle before trying to start
  1. 2008 Grand Prix HUD Date Issue
    By Exodude25 in forum Audio, Security & Visual Electronics
    Last Post: 07-29-2016, 07:12 PM
  2. 2008 Grand Prix GXP Alternator issue
    By 1977 in forum General Tech Discussion
    Last Post: 03-22-2013, 09:37 AM
  3. Issue on 2008 Grand Prix
    By ibra0078 in forum Introductions/Noob Questions
    Last Post: 03-14-2013, 06:29 AM
  4. 2008 Grand Prix Door Lock Issue
    By 2008GrandPrix in forum General Tech Discussion
    Last Post: 03-27-2012, 05:03 PM
  5. 2008 Grand Prix no start issue
    By supernac in forum General Tech Discussion
    Last Post: 08-22-2010, 11:57 AM
