Thread: Tire low warning
Results 1 to 6 of 6
  1. #1 Tire low warning
    Mar 2016
    Usa
    This weekend, my 2008 grand prix just started giving me both the yellow light by the dash and the message that the low tire warning system has been activated message. I checked all my tires and none of them have a leak or are even low. My left front tire is the only tire not showing a psi reading on the HUD though so I know its an issue with that tire. Does anyone know how to fix or how much it costs to fix the sensor in that tire as I am assuming thats the problem?
  2. #2 Re: Tire low warning
    I'd call your local tire places and see if they replace the batteries.
  3. #3 Re: Tire low warning
    They will just replace the sensor.
    You have to basically completely destroy the sensor to even get at a battery in the sensor. They are molded around the battery with plastic and glue.
    Most sensors are less than $50 even at the auto parts store and a shop may get even a better deal plus the install. Start calling around to see what they say.
  4. #4 Re: Tire low warning
    GTP Level Member
    Oct 2014
    I had one replaced at costco for like 35 bucks.
  5. #5 Re: Tire low warning
    Mar 2016
    Usa
    Quote Originally Posted by markpa View Post
    Does anyone know how to reset the message on the heads up display?
  6. #6 Re: Tire low warning
    A shop would reset the system if a new sensor was installed.
    If the sensor is never fixed the message will always be there.
  1. INFORMATION Review - Tire Gel vs Tire Coating
    By The Guz in forum Detailing Tips and Tricks
    Last Post: 04-10-2016, 11:04 PM
  2. Tire pressure warning wont shut off
    By ms3206 in forum General Tech Discussion
    Last Post: 08-23-2011, 11:20 PM
  3. just a warning
    By hunterbow4 in forum Introductions/Noob Questions
    Last Post: 11-17-2010, 07:05 AM
  4. tire rack ? about this tire
    By GTPJOE90 in forum Tires & Wheels
    Last Post: 03-09-2009, 09:12 PM
  5. Tire Pressure Warning
    By BHMJohn in forum General Tech Discussion
    Last Post: 09-30-2008, 08:38 AM
