Thread: 2009 g6
Results 1 to 11 of 11
  1. #1 2009 g6
    MINNESOTA
    I just bought a 2009 G6 GXP
    And the engine took a crap
    The engine started knocking a and the car shuts off
    So I have a question.
    my G6 has the 3.6
    Can I install a 3.5 or a 3.9in it
  2. #2 Re: 2009 g6
    GTX Level Member cheatah faheatah's Avatar
    May 2016
    Rouge Island
    Uh, warranty ?
    For the record : I am NOT a naked meth-head who shoves rocks up my butt.
  3. #3 Re: 2009 g6
    MINNESOTA
    No warranty
    It expired as soon as I drove of his property
  4. #4 Re: 2009 g6
    May 2016
    Rouge Island
    smh
  5. #5 Re: 2009 g6
    No, you must replace it with a 3.6.
    The 3.5 and 3.9 are totally different and will not function with the computer/wiring in the car. The 3.6 is specific to that model and computer/wiring.
  6. #6 Re: 2009 g6
    MINNESOTA
    Thank you
  7. #7 Re: 2009 g6
    MINNESOTA
    Is the Pontiac G6 the only one that has this size motor
    That will fit this car
    Or is there other GM brands that have this same size motor
    Thanks
  8. #8 Re: 2009 g6
    The LY7 was put in several cars.
    GM High Feature engine - Wikipedia
    You'd need to find one from another LY7 equipped vehicle, then swap over any brackets or whatever that is different. You will need to do a lot of research to make sure what else you may run into when swapping engines.
  9. #9 Re: 2009 g6
    MINNESOTA
    Thanks
    One question- this guy has a Short Block 3.6L GM engine. he says it will Fit 07-09 Saturn Aura, Chevy Malibu, Pontiac G6, and Saturn Vue
    But its just the block
    Will that work
    What would I need to look for when looking at it
    Thank again
  10. #10 Re: 2009 g6
    GTP Level Member buickman104's Avatar
    NYC
    While the engine is out please consider changing the timing chains and tensioners. Those High Feature 3.6 Liter engine are infamous for eating the timing chains/tensioners. I was doing research for a friend and was scared away from those engine because the job is just easier once the engine is out of the car and it is more of a maintenance item!!!
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  11. #11 Re: 2009 g6
    St. Louis
    Honestly I'd just check car-part.com, LKQ or another JY in the area and see if you can score a good running engine, do the recommended timing chain/tensioners while out and drop it in. That would be the quickest way to get it back on the road with minimal chances of a "surprise" if you don't build it right. Then again, if you have the time/money to properly build it from scratch then by all means, build away!
  1. Looking Into A New Ride..2009 G8 GT MGM
    By GrandPrix06GT in forum Off Topic Discussion
    Last Post: 07-23-2014, 07:43 AM
  2. 2009 Azera
    By GrandPrixLover in forum Other Vehicles
    Last Post: 07-09-2012, 11:00 AM
  3. As of 2009...
    Last Post: 11-30-2011, 09:40 PM
  4. My new 2009 model GTO!
    By Reptile in forum Off Topic Discussion
    Last Post: 05-05-2009, 11:47 AM
