Thread: Disconecting Fuel rail
Results 1 to 6 of 6
  1. #1 Disconecting Fuel rail
    Jan 2018
    Morgantown
    I'm curious about how to take my fuel rail line connectors off on my 2001 gtp I've already bent the fuel rail trying to disconnect them needed a new one anyway but how do I get it off
  2. #2 Re: Disconecting Fuel rail
    you need a fuel line quick disconnect tool i have this set 4 Piece Fuel and Auto Trans Line Disconnect Tool Set
    you close it over the fuel rail line, then push it into the clip, push the line in and push the tool all the way in and then pull the line off the rail.
    drain the fuel pressure first or you'll take a gas bath.
  3. #3 Re: Disconecting Fuel rail
    Jan 2018
    Morgantown
    Oh okay thanks
  4. #4 Re: Disconecting Fuel rail
    GTX Level Member wstefan20's Avatar
    Aug 2017
    Raytown, MO
    Oh, and while you're there, I recommend replacing the o-rings even if they're not leaking yet. Any viton o-rings work, I think I had to buy two packs of assorted viton o-rings to find the right ones. A bit tricky to get to, but it's doable if you have a long sharp pick (just make darn sure not to poke the new o-ring and clean everything with brake clean really well.
  5. #5 Re: Disconecting Fuel rail
    Jan 2018
    Morgantown
    Quote Originally Posted by wstefan20 View Post
    Okay sounds great btw I pm'd u
  6. #6 Re: Disconecting Fuel rail
    Jan 2018
    Morgantown
    pm'd you again
  1. Replies: 7
    Last Post: 07-15-2015, 03:41 PM
  2. Modded fuel rail leaking( should i get fuel logs??? )
    By Hardonyomom in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-31-2014, 05:38 AM
  3. The retainer/clip the secures the fuel line to the fuel rail.
    By Sudden in forum Wanted To Buy - Parts
    Last Post: 06-22-2013, 05:20 PM
