Thread: Just bought a 98 gtp and can't figure out what's wrong with it
Results 1 to 19 of 19
  1. #1 Just bought a 98 gtp and can't figure out what's wrong with it
    Sep 2017
    Texas
    I bought it a couple months ago and all of my windows and sun roof have stopped working, and my ob2 plug won't hook up to anything either. The radio works but doesn't show anything when I first turn it on I have to drive for about 5 minutes and then it comes up
  2. #2 Re: Just bought a 98 gtp and can't figure out what's wrong with it
    obd2 port is the fuse for the power port. if the power port works now you got bigger issues.
    theres two fuse boxes, under the hood and glove box. check the fuses for the windows.
  3. #3 Re: Just bought a 98 gtp and can't figure out what's wrong with it
    Sep 2017
    Texas
    I changed the power port fuse a couple times to make sure that wasn't the problem but still nothing.
    I will check my window fuses also, is their a sunroof fuse?
  4. #4 Re: Just bought a 98 gtp and can't figure out what's wrong with it
    id think so. theres a fuse map showing you what they power. read it and check the fuses. both fuse boxes. might have two. never know.
  5. #5 Re: Just bought a 98 gtp and can't figure out what's wrong with it
    Sep 2017
    Texas
    Alright I will check that tonight and get back to you on that.
  6. #6 Re: Just bought a 98 gtp and can't figure out what's wrong with it
    Kinda sounds ignition switch related with multiple electrical issues that happened all at once.
  7. #7 Re: Just bought a 98 gtp and can't figure out what's wrong with it
    if the fuses check out next could be the drives side window switch, it goes bad the windows can quit working. try playing with the child lock switch. might come back to life.
    then the wires from the cab to the door can break, you'd have to pop the accordion tube, the inside kick panel, and the car door inside panel off and look for damaged wires.
  8. #8 Re: Just bought a 98 gtp and can't figure out what's wrong with it
    Sep 2017
    Texas
    I will make sure all the drivers side is good also.
    What problems all happen with the ignition switch going bad?
  9. #9 Re: Just bought a 98 gtp and can't figure out what's wrong with it
    Sep 2017
    Texas
    Oh the ac/heater isn't working either if that matters, it sounds like it is when turned on but no air comes out, in not sure if that connects to this or not.
  10. #10 Re: Just bought a 98 gtp and can't figure out what's wrong with it
    heater fan, parking lights not working, odd ball crap.
  11. #11 Re: Just bought a 98 gtp and can't figure out what's wrong with it
    Sep 2017
    Texas
    And my parking lights don't work either, and my truck sensor is always on.
  12. #12 Re: Just bought a 98 gtp and can't figure out what's wrong with it
    https://sparkys-answers.com/2009/09/...-changing.html and here your how to. its not all that bad of a job, new one is about 50 bucks off rockauto.
  13. #13 Re: Just bought a 98 gtp and can't figure out what's wrong with it
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by Mrkt View Post
    All kinds of things. Most commonly is no HVAC and no auto on lights. You can replace the ignition switch, or do this "ignition saver mod":
    http://www.clubgp.com/newforum/tm.as...mode=1&smode=1
    Here's schematics on the fuse panels; they are for 2002, but should be the same for 98:
    http://chrisb.users.superford.org/Grand_Prix/All_Data/Fuse_Block_Interior_Page_1.pdf
    http://chrisb.users.superford.org/Gr...ood_Page_1.pdf
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  14. #14 Re: Just bought a 98 gtp and can't figure out what's wrong with it
    Sep 2017
    Texas
    Thank you very much for your help, definitely helped alot, I didn't think it was all connected
  15. #15 Re: Just bought a 98 gtp and can't figure out what's wrong with it
    Sep 2017
    Texas
    I will definitely give that mod a good look to see if I should do that. And thank you for the schematics also.
  16. #16 Re: Just bought a 98 gtp and can't figure out what's wrong with it
    Jul 2010
    Coquitlam,BC,Canada
    No problem. I bought a new ignition switch a few years ago, with the plans of changing it. When I did, I found that all my aftermarket alarm wiring was tapped into the switch wiring, so I changed plans and just did the mod. Been almost 3 years and it is working just fine, so it is a viable option.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  17. #17 Re: Just bought a 98 gtp and can't figure out what's wrong with it
    Sep 2017
    Texas
    That is definitely good to know that it's actually worked for you for so long
  18. #18 Re: Just bought a 98 gtp and can't figure out what's wrong with it
    Mar 2017
    Internet
    Seems the guys have you going right on most of the big stuff. Your lack of radio display is a bad bulb. Its in the radio and possible to change. I typically pick up a fresh one on ebay
  19. #19 Re: Just bought a 98 gtp and can't figure out what's wrong with it
    Sep 2017
    Texas
    I'll be replacing the radio with one with a aux outlet on it so im not to worried about the radio.
  1. HELP!!! cant figure out whats wrong
    By 02gtp1990 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-17-2021, 07:07 PM
  2. Can't figure out what's wrong with this Flojet
    By CBWhite in forum General Tech Discussion
    Last Post: 04-29-2016, 10:28 PM
  3. See if you can help me figure out what wrong...
    By bsharpminor in forum Other Vehicles
    Last Post: 07-05-2012, 05:31 PM
  4. Im new to this forum and i cant figure out whats wrong with my car
    By fremmy182 in forum General Tech Discussion
    Last Post: 09-07-2010, 11:07 AM
  5. Trying to figure out whats wrong with my car
    Last Post: 05-08-2009, 01:13 PM
