Thread: Module locations
Results 1 to 7 of 7
  1. #1 Module locations
    Oct 2017
    Churubusco
    I am looking for locations on an ECM and a PCM on A 04 Grand Prix and a diagram for under driver side dash.
  2. #2 Re: Module locations
    Kemmerer, Wyoming
    the ecm and pcm should be located under the airbox. no idea where to find the diagram.
  3. #3 Re: Module locations
    ECM = PCM, they are both the same things.
  4. #4 Re: Module locations
    Oct 2017
    Churubusco
    I was told by summit city Chevrolet they aren't.
  5. #5 Re: Module locations
    Oct 2017
    Churubusco
    Quote Originally Posted by SgtMarshal View Post
    Trying to figure out if anything is missing under the dash because there is three wires that don't plug in to anything.
  6. #6 Re: Module locations
    Then they should have given you better information as to what they are talking about then.
    The PCM is the power control module that is located in the airbox, the electronic control module or the ECU as other call it is the same thing if you ask me. It controls the engine and transmission.
    The other modules in the car are the ABS module, the BCM or body control module that's normally behind the glove box somewhere and the airbag stuff.
    That car is too old to have things like FPCM and TCM for the fuel pump and transmission.
  7. #7 Re: Module locations
    GTX Level Member wstefan20's Avatar
    Aug 2017
    Raytown, MO
    I know from the junkyard the vcim/ on star module is under the center console trim, don't have a diagram but easy to get to. The Sirius xm module is in trunk and pcm is under air box bcm is under driver's side dash. Hope that helps some
  1. o2 sensor locations 99 GTP
    By nathnn99 in forum Introductions/Noob Questions
    Last Post: 05-08-2015, 03:24 AM
  2. Supercharger Bolt Locations - Need Help
    By Primal in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-21-2013, 07:38 PM
  3. xpz cam pushrod length locations?
    By theonlysi1 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-03-2011, 02:22 PM
  4. Switch locations
    By iceman977th in forum Visual/Body Modifications
    Last Post: 06-07-2011, 09:15 AM
  5. Good Ballast locations.
    By RyanL in forum Visual/Body Modifications
    Last Post: 03-23-2010, 03:48 AM
