Background:
Boyfriend was driving to work and came to a stop. He went to hit the gas and the engine stalled. All the electrical was still on in the car and it was in drive. He put it back in park took the key out and tried to start again - nothing. You can crank the car but it does not turn over.
He pushed it to a safe spot and we had it towed home. The diagnostic test gave a "Throttle Body Module Error." We've since replaced the throttle body and the ignition switch. I have reset the security system with by turning the vehicle to the ON position leaving it for 10 minutes, turning to OFF, wait 5 seconds and repeating two more times. Directly after doing that the key now STICKS in the ignition when cranking. You crank the car, let go, and the key will continue to crank the car for about a 1-2 seconds after you've pulled away. Since replacing the throttle body the dash is now also reading "reduced engine power".
We're all convinced it's something completely stupid and a semi-easy fix. Let me know you're thoughts! (After I reset the security system and there was no improvement we unplugged the battery for 30 minutes to try and reset the system. There was no change.)
Do you think we received a bad throttle body? It sounds worse when cranking now than it did with the original throttle. We did not have the reduced engine power error before replacing the throttle body either.
PS. We've had previous problem with hard starting with this vehicle and had work done (replaced catalytic converter and cleaned the throttle body). It has worked great since we had it serviced and has never stalled until now.
PLEASE HELP!
