Thread: Delayed cranking issue w/ 2005 Pontiac Grand Prix
Results 1 to 13 of 13
  1. #1 Delayed cranking issue w/ 2005 Pontiac Grand Prix
    SE Level Member Hotsuma9's Avatar
    Jul 2017
    South Carolina
    This has been going on for over a month now. Whenever I crank the car, it feels like the motor turns once then stalls, then after a few seconds it'll usually crank up. Other times it'll crank right up with little to no engine stalling. I'm a little concerned about the stalling because it feels like the motor is trying to lock up. Any guesses to what could be causing this to happen?
    I sometimes do minor work on my car (2001 Pontiac Grand Am) so I already have an OBD 2 scanner. When I scanned this cars ECU it gave me these errors:
    Delayed cranking issue w/ 2005 Pontiac Grand Prix Attached Images
  2. #2 Re: Delayed cranking issue w/ 2005 Pontiac Grand Prix
    sounds like its time for a new battery, or at min get it tested.
    those codes are not related, but get to fixing them.
  3. #3 Re: Delayed cranking issue w/ 2005 Pontiac Grand Prix
    Jul 2017
    South Carolina
    We did discuss the battery but I have yet to test it with my multimeter. I sure hope that's all it is.
  4. #4 Re: Delayed cranking issue w/ 2005 Pontiac Grand Prix
    you need a load tester, hit up a parts store, autozone is free for the test. make sure they test volts car off, car at idle, then load test it.
    your alt could also be going bad and not putting out a full charge to the battery making it weaker. same test will tell you whats up.
    and you 04 up guys got some funky neg cable clamp, that things always suspect.
  5. #5 Re: Delayed cranking issue w/ 2005 Pontiac Grand Prix
    Jul 2017
    South Carolina
    Ok. Thanks for the info!
  6. #6 Re: Delayed cranking issue w/ 2005 Pontiac Grand Prix
    Nov 2012
    Madison
    You could use a throttle body cleaning and get some MAF cleaner spray while your there(parts store).
    If you haven't done this yet, you need to. It could be your starting problem.
  7. #7 Re: Delayed cranking issue w/ 2005 Pontiac Grand Prix
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    Quote Originally Posted by spazzz View Post
    I'm going to say battery also,exactly what my 06 did when battery was on it's way out. Dirty throttle body is an issue on the 04+ but it will crank just fine just no start when that's going on.
  8. #8 Re: Delayed cranking issue w/ 2005 Pontiac Grand Prix
    Oct 2011
    Toledo, OH
    It could be a fueling issue. Try priming the pump once or twice before cranking, see if that changes anything.
    7"
  9. #9 Re: Delayed cranking issue w/ 2005 Pontiac Grand Prix
    Jul 2017
    South Carolina
    Ok. I will get on it and let you guys know.
  10. #10 Re: Delayed cranking issue w/ 2005 Pontiac Grand Prix
    Jul 2017
    South Carolina
    Ok. Yeah. It was most definitely the battery! Put in a new one and it fires up right away. Thanks, guys!
  11. #11 Re: Delayed cranking issue w/ 2005 Pontiac Grand Prix
    Jul 2017
    South Carolina
    One last question... The bolt that goes on the negative clamp...Exactly what size is it? I lost it while swapping batteries.
  12. #12 Re: Delayed cranking issue w/ 2005 Pontiac Grand Prix
    if you dropped it down by the belts, id bet you money its sitting in the motor mount bucket. anything i drop ends up there, i drop down a magnet on a flex stick and fish stuff out all the time.
  13. #13 Re: Delayed cranking issue w/ 2005 Pontiac Grand Prix
    Jul 2017
    South Carolina
    Ok. I'll see if I can fish it out with a magnet.
  1. 2005 grand prix gt neutral safety switch issue?
    By zorak1066 in forum General Grand Prix Discussion
    Last Post: 08-08-2015, 11:10 AM
  2. Pontiac grand prix 2005
    By babyboomer in forum Introductions/Noob Questions
    Last Post: 01-05-2015, 12:37 PM
  3. 2005 Grand Prix Parking Brake issue
    By Chainsaw6966 in forum Brakes/Suspension/Chassis
    Last Post: 11-08-2012, 11:29 AM
  4. 2005 Grand Prix GTP Rear Brake Issue
    By whitefeathersnpr in forum Brakes/Suspension/Chassis
    Last Post: 08-24-2012, 07:40 AM
