Thread: Trailing Arm Bushing Squeak
Results 1 to 20 of 22
  1. #1 Trailing Arm Bushing Squeak
    Donating Users Burgundyman's Avatar
    What type of grease can I use to lubricate between bushing and trailing arm bracket?
    1998 Grand Prix - GTP
    RED- 4 Door Sedan
  2. #2 Re: Trailing Arm Bushing Squeak
    I sprayed it with Wd40 and it stopped. This tells me where the squeak is coming from.
    RED- 4 Door Sedan
  3. #3 Re: Trailing Arm Bushing Squeak
    Get a tube of that marine water resistant grease that they use in boats.
    That part of the car is subject to a alot of water when it rains and regular grease can be washed away.
  4. #4 Re: Trailing Arm Bushing Squeak
    Perfect. Thank you.
    RED- 4 Door Sedan
  5. #5 Re: Trailing Arm Bushing Squeak
    Nov 2012
    Madison
    It looks like you could drop it easy enough to get at it better.
    You need a silicone grease with PTFE so it doesn't effect the rubber.
    Or just keep spraying it with WD40 Dry Lube PTFE spray...good stuff
  6. #6 Re: Trailing Arm Bushing Squeak
    Nov 2012
    Madison
    What I use....Mission Automotive Dielectric Grease / Silicone Paste / Waterproof Marine Grease
    https://www.amazon.com/Dielectric-Gr.../dp/B016E5E59G
  7. #7 Re: Trailing Arm Bushing Squeak
    Where does one get silicone with PTFE?
    RED- 4 Door Sedan
  8. #8 Re: Trailing Arm Bushing Squeak
    Nov 2012
    Madison
    Quote Originally Posted by Burgundyman View Post
    well from that link for one.
  9. #9 Re: Trailing Arm Bushing Squeak
    Looks like I will have to wait before taking things apart. I am replacing lateral arms so it might be a good idea to lubricate all at once.
    RED- 4 Door Sedan
  10. #10 Re: Trailing Arm Bushing Squeak
    All I could find locally is sil-glyde
    RED- 4 Door Sedan
  11. #11 Re: Trailing Arm Bushing Squeak
    Nov 2012
    Madison
    That will work. Seems to be a favorite for a lot of people from what I read
  12. #12 Re: Trailing Arm Bushing Squeak
    Lateral arms all removed. Rear bolts by fuel tank was a pita.
    RED- 4 Door Sedan
  13. #13 Re: Trailing Arm Bushing Squeak
    RED- 4 Door Sedan
  14. #14 Re: Trailing Arm Bushing Squeak
    I suspect the metal bushing on trailing arm is rubbing against trailing arm bracket.
    RED- 4 Door Sedan
  15. #15 Re: Trailing Arm Bushing Squeak
    This is from Rare Parts which supposedly is an upgrade to OEM
    RED- 4 Door Sedan
  16. #16 Re: Trailing Arm Bushing Squeak
    RED- 4 Door Sedan
  17. #17 Re: Trailing Arm Bushing Squeak
    Nov 2012
    Madison
    You must have read the reviews.
  18. #18 Re: Trailing Arm Bushing Squeak
    Quote Originally Posted by spazzz View Post
    I did. Given how much work it is to change lateral and trailing arms, I wanted to get it right.👍
    RED- 4 Door Sedan
  19. #19 Re: Trailing Arm Bushing Squeak
    GTX Level Member cheatah faheatah's Avatar
    May 2016
    Rouge Island
    EVERYTHING goes better with luuuuuube.....
    For the record : I am NOT a naked meth-head who shoves rocks up my butt.
  20. #20 Re: Trailing Arm Bushing Squeak
    Update...after replacing trailing arms, track bar, sway bar, etc...I lubed bushings and had a wheel alignment. No squeaks. Drives like a dream.
    RED- 4 Door Sedan
  1. New brakes, odd squeak
    By Buggsy in forum Brakes/Suspension/Chassis
    Last Post: 01-31-2013, 07:23 PM
  2. want to know what my squeak is
    By Fedewaj in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2010, 08:59 PM
  3. heater squeak
    By 98GTPCALGARY in forum General Tech Discussion
    Last Post: 03-23-2010, 11:49 AM
  4. Right front Squeak
    By gvandal in forum General Tech Discussion
    Last Post: 12-03-2009, 07:37 AM
  5. Got a squeak that won't go away...
    By Sandman in forum Brakes/Suspension/Chassis
    Last Post: 10-02-2009, 06:12 PM
