Thread: Guidepoint gsm gprs module
Results 1 to 4 of 4
  1. #1 Guidepoint gsm gprs module
    Jun 2017
    North Carolina
    I found this module in the GP GXP I just got. It was hanging behind the radio from its 12-pin plug with one of two small, gold high-frequency type screw connections connected. It wasn't mounted correctly and was clanking against a trim panel so I carefully removed it and nothing seems to have been affected. Also my radio reception seems better (it sucks) and this says it's a GSM device, and has an FCC transmission warning label, so it kind of makes sense.
    Anyone know what this is? My research says it's a GPS anti-theft device. If so, how do I activate the service? I'll re-install if it's useful.
  2. #2 Re: Guidepoint gsm gprs module
    Sep 2015
    Cheyenne, WY
    Are you financing the car?
    I only ask because it seems that it's a locator device given the fact that it was just left hanging.
    Are the wires in a factory harness or loose?
    If it is not stock equipment, disconnect it.
    2007 Antique Bronze Metalic Grand Prix GT...bone stock.
  3. #3 Re: Guidepoint gsm gprs module
    May 2017
    Colorado
    If it is a tracking device, who did you buy it from and what was their story?
    It could be a tracking device their spouse put in the car prior to you getting involved. Maybe their spouse didn't get a chance to remove it or didn't plan on the owner selling the car.
  4. #4 Re: Guidepoint gsm gprs module
    Jun 2017
    North Carolina
    Thanks for the replies, guys. It was hanging from what looked like a custom harness w/ several cut wires (coming *from* the guidepoint). There was also an apparently associated button on the instrument panel which I couldn't figure out. It was rectangular w/ two square buttons, one w/ a phone-looking icon and the other a sort of grid, w/ a flashing (when power off) blue LED between them. That LED no longer flashes after disconnect.
    I'll check w/ the guy I got it from. He hadn't had it long and didn't know about a few things so I don't expect an answer.
  1. Aux module for a 04.
    By WolvesSoulZ in forum Audio, Security & Visual Electronics
    Last Post: 06-01-2014, 08:55 AM
  2. Tac Module
    By Skeeve in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-25-2010, 11:30 PM
  3. abs module
    By tlaloczint in forum Brakes/Suspension/Chassis
    Last Post: 02-20-2010, 11:43 AM
  4. Module?
    By GTPluv in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-22-2009, 05:16 PM
