Thread: SC 3800 series 3 Burning Oil
Results 1 to 8 of 8
  1. #1 SC 3800 series 3 Burning Oil
    Jun 2017
    My Grand Prix GTP has 177,000 miles on it and is burning oil. When I stop driving there is smoke/steam coming out of the dipstick and oil cover. It only needs a top off of oil every couple weeks so its not too severe, but the smoke scares me. I havent noticed any blue exhaust, so I was wondering if this issue could be as simple as a pcv valve? Please help I love my murdered out grand prix and I don't want to get rid of it due to a blown engine or costly fixes.
    Thanks,
    Sam
  2. #2 Re: SC 3800 series 3 Burning Oil
    Kemmerer, Wyoming
    I've had the same thing happen, in my case, I was intercooled at the time, and one or both of the pcv passages on the intercooler was plugged with the rtv I used to seal the intercooler to the supercharger and lower intake manifold. I would expect something to have malfunctioned with your pcv system like your pcv valve.
  3. #3 Re: SC 3800 series 3 Burning Oil
    Jun 2017
    So you think it could be as simple as a 10$ pcv valve that I would just need to replace?
  4. #4 Re: SC 3800 series 3 Burning Oil
    Kemmerer, Wyoming
    it's possible
  5. #5 Re: SC 3800 series 3 Burning Oil
    Jun 2017
    Okay so when I took off my supercharger cover to take a look at the pcv valve, I noticed a cylinder type thing on top of the cap?
  6. #6 Re: SC 3800 series 3 Burning Oil
    Kemmerer, Wyoming
    the pcv valve sits down inside the supercharger with a spring on top of it with 1 or 2 o rings. I think I used a pair of needle nose pliers to get the valve out.
  7. #7 Re: SC 3800 series 3 Burning Oil
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    When I had smoke coming out from my dip stick tube and valve cover, it happened only after my LIM gasket change. I think it was a small amount of coolant burning off that would steam up when the engine got hot. After my next oil change, the issue went away.
  8. #8 Re: SC 3800 series 3 Burning Oil
    Nov 2011
    NY
    Pcv valve if you haven't changed it recently... Some engine cleaner and identify if there's leaks, valve cover gasket is quite common. Then go from there... Every couple of weeks means how much driving time/mileage?
  1. How to tell the difference between a 3800 Series II and Series III engine/ L67 vs L32
    By DoUEvenShift NoBroItsAuto in forum Introductions/Noob Questions
    Last Post: 03-14-2014, 01:12 AM
  2. Will a series 1 3800 tranny fit a series 2
    By 2002grandprixgt in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-20-2012, 01:06 AM
  3. 2004 series 3 3800 swap to 1998 series 2 car?
    By carpenterbronco in forum General Tech Discussion
    Last Post: 04-13-2010, 11:12 PM
  4. 3800 Series II MPG?
    By PsychoGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-14-2009, 12:40 AM
