Alright so I tried to fill my car up with gas and it was almost on E the light was on. Shortly after turning the pump on it started pumping really slow. I tried pulling the nozzle out a little bit and it would still go really slow. Then shortly after putting in about 2 gallons gas started leaking everywhere from what seems to be the filler neck not venting properly. The other day I had no problem putting in a full tank of gas at what would be the normal speed of the gas pump. I tried different angles with the nozzle and all that.
Sent from my SM-N900V using Tapatalk
