So 3 weeks ago i posted about putting mixed gas ( oil and gas) in my tank and had a studder problem where at WOT it would lag and cut out a bit, the SES light would not flash so it wasn't misfiring. well now to present day i was on the highway coming back from a little cruze and getting onto the highway in third gear i would go half throttle and it would maybe studder a bit and jump down a few 100 rpm and then continue to rev outl, if i put it into D it would go way down in RPM like 1400 or somewhere close. it would cruze okay but if at anytime i slam the throttle a bit like half way you could feel it bog and kinda be slow to pick up, i didn't try and do a 4th gear pull as i would never do that but i know if i did it would bog and studder to much. Low RPM driving is perfectly fine and it shows no signs of bogging. At first while on the highway and jabbing the throttle it almost feels like it's a trans problem, putting it in Performance shift would take away some of that bog but it would still be noticeable. I want to replace the fuel filter as it's pretty old but i'm not sure if that would make a massive difference. Planning on getting a over kill PCM but if it keeps doing this idk if that would be worth it....
Fresh 91 non ethanol gas and a brand new race/highflow cat with a new rear O2. The car does have a leaking lower intake gasket but that will re fixed tomorrow. Not sure if that has something to do with it.
mods are as followed 3in dp catted, TR55 NGK, Front PLOG, rez del, FWI
Any help would be great, thanks.
