Thread: slow leak under 1997 grand prix gtp video inculded
Results 1 to 2 of 2
  1. #1 slow leak under 1997 grand prix gtp video inculded
    Mar 2017
    Iowa
    Can anyone tell me what is most likely causing this? It only leaves a small amount of liquid on the ground after every drive. https://vid.me/RI1Y thanks in advance
  2. #2 Re: slow leak under 1997 grand prix gtp video inculded
    if the fender is dry id think the water pump took a dump, it leaks out a weep hole on the back bottom of the pump.
    car off, with two hands grab the wp pulley, push with one hand, pull with the other then see if it rocks a little bit, if it moves, you need a new pump.
    you can also use a mirror on a stick to see if its wet under the pump.
    you also might notice a strip of fluid on your hood that lines up with the belts, thats a water pump as well.
  1. Problems with me 98 Grand Prix GTP with video.
    By resendez88 in forum Introductions/Noob Questions
    Last Post: 04-12-2013, 07:31 PM
  2. video on intake gasket replacement on 1997 grand prix gtp
    By mitcheld44 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-27-2012, 08:45 AM
  3. Grand prix tribute video
    By cameron92 in forum Off Topic Discussion
    Last Post: 08-01-2011, 10:59 PM
  4. video of my grand prix
    By gpgtp99 in forum General Tech Discussion
    Last Post: 01-24-2010, 12:25 AM
  5. Six Speed Grand Prix Video
    By njbrain in forum Off Topic Discussion
    Last Post: 10-15-2008, 01:29 AM
