Thread: What coolant color should a 1999 Grand prix GTP have?
Results 1 to 8 of 8
  1. #1 What coolant color should a 1999 Grand prix GTP have?
    Apr 2017
    Ontario
    Hey guys
    I check my engine bay quite a lot, i've been meaning to flush the coolant out of my car (not because it's bad but because i want to ) and mines green. I heard you're suppose to use orange? I've been using green Prestone for years and years and the car runs super well. The Temp gauge doesn't go over 100C ever. it sticks around 80c in the summer and in the middle of that in the winter.
    What do you guys think?
    Thanks!
    99 GTP: DIY FWI-3in CDP-rez del-plog-napa spark wires COME ON WILL I WANT MY TUNE!!!!!!<3 Intercooling next
    <3 PROUDLY Canadian / PROUDLY Austrian "Look, Gasoline's perfectly safe.....until you introduce ol Orange."
  2. #2 Re: What coolant color should a 1999 Grand prix GTP have?
    St. Louis
    Run the green. As long as you change it at regular intervals and refill using distilled water you should have no issues. I switch both my GP and Bonneville to green years ago and have yet to have a problem related to the coolant type.
  3. #3 Re: What coolant color should a 1999 Grand prix GTP have?
    Apr 2017
    Ontario
    I was super worried, I've ran that in my car since we got it 4 year ago (starting modding a year ago) and i was thinking i was hurting it. what's the regular temp for these cars as dailies? every time i'm out i'm peering down at the temp gauge hoping it doesn't get to high. Though I've never had a heat problem. (trans cooler next?)
  4. #4 Re: What coolant color should a 1999 Grand prix GTP have?
    Factory is dexcool, which is orange.
    Many switch to green, it makes no difference.
    195-200ยบ is the avg coolant themp they will run at with stock thermostat on the open road. Factory gauge cluster does not truely tell you the coolant temp, it's not something that is very spot on. The first big line past 160 is around 190ish.
  5. #5 Re: What coolant color should a 1999 Grand prix GTP have?
    Apr 2017
    Ontario
    I've heard to stay away from dexcool.....not even the guys at my work like that stuff. And okay, I was thinking of putting in a fan switch so i can turn the fans on when ever i want. But i think a new PCM tune will already do that for me.
  6. #6 Re: What coolant color should a 1999 Grand prix GTP have?
    Any of the dexcool stuff made after like 2009-2010ish or so (they switch how it was made) is just fine to use. Both my old 2010 and current 2012 silverado run factory dexcool and it has no issues. Just over 100k on my 2012 with the factory stuff and it's still bright orange, no sludge/brown stuff.
  7. #7 Re: What coolant color should a 1999 Grand prix GTP have?
    St. Louis
    I wouldn't bother with a fan switch, just let the PCM do it's thing. These engines are designed to run hot from the factory, IIRC the high speed fan comes on around 228F or so.
  8. #8 Re: What coolant color should a 1999 Grand prix GTP have?
    I can't car too good. SaukRapids's Avatar
    May 2016
    MN
    Quote Originally Posted by FordMan77 View Post
    Very much agreed. I had aux fan switch from uhh ..pfyc, I think.
    I didn't feel it benefited much unless it was over 100 ambient in stop n go. Even then I thought it might be kinda hard on the charging system, so barely used it.
  1. What color rims for a Maroon Grand Prix?
    By qfields93 in forum Introductions/Noob Questions
    Last Post: 05-06-2015, 06:13 AM
  2. Grand prix bumper color code
    By kking89 in forum Visual/Body Modifications
    Last Post: 04-07-2011, 11:26 AM
  3. Favorite Color in 04+ Grand Prix's
    By hazards280 in forum Visual/Body Modifications
    Last Post: 10-22-2010, 05:50 AM
