Thread: L/F wheel bearing GP 2008
Page 1 of 3 123 LastLast
Results 1 to 20 of 49
  1. #1 L/F wheel bearing GP 2008
    Mar 2013
    Canada
    Going to try to tackle changing the wheel bearing on the driverside in my GP 2008 as it's making noise. Right one was already replaced few months ago from at local garage as it was way to cold outside for me to do it. Anyways it looks straight forward however any useful tips People might have? Any special tools I need to take out the wheel hub? Is the axel nut socket size 34 or 36? What are the torque specifications for the wheel hub bolts and the axel nut. Thanks
    Sent from my SM-G935W8 using Tapatalk
  2. #2 Re: L/F wheel bearing GP 2008
    Mar 2017
    Internet
    No special tools, unless you don't have the tools listed below.
    13mm socket
    15mm socket
    19mm socket
    Ratchet
    breaker bar or air gun
    Coat hanger or something to hang the caliper on the spring
    Hammer (3lb+ preferrable)
    Jack
    Jack stand
    Torque wrench if you want to be precise. I always gunned the axle nut back on and didn't have troubles.
    Axle nut if stock should be a 34mm. A lot of replacement axles come with a 36mm.
  3. #3 Re: L/F wheel bearing GP 2008
    Mar 2013
    Canada
    Thanks, would you know the torque specifications for the axel nut and wheel hub nuts when putting them back on
  4. #4 Re: L/F wheel bearing GP 2008
    tq is 118
  5. #5 Re: L/F wheel bearing GP 2008
    Mar 2017
    Internet
    wheel bearing you buy likely has a scrap of paper with what it wants.
    There's a torque spec thread in the How to Section. I think FiveFingerDeathPunch posted it or in it. I wouldn't know those specs.. you won't get a good straight shot at the bearing bolts, so tight works and the the axle nut is another nice and tight will work fine...there is a spec though.
  6. #6 Re: L/F wheel bearing GP 2008
    Mar 2013
    Canada
    K thanks guys
  7. #7 Re: L/F wheel bearing GP 2008
    May 2016
    Lincoln, Nebr
    118 lbs is correct. If you can fit your axle nut thru the wheel center cap, it's easier to torque with the wheel attached and on the ground. And if you haven't bought the bearing yet, I would recommend Moog.
  8. #8 Re: L/F wheel bearing GP 2008
    Mar 2017
    Internet
    You can also have a helper standing on the brakes, jam a little something in the rotor fin up against the caliper bracket. It all works.
  9. #9 Re: L/F wheel bearing GP 2008
    Jul 2010
    Coquitlam,BC,Canada
    To crack the hub nut, put the spare tire on, lower the car back to the ground, and have at her. I cheated with a 5" roof rack bar. LOL
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  10. #10 Re: L/F wheel bearing GP 2008
    i used to be able to the spare tire trick, but the spare dont fit over f body brakes.
    now i drop a screw driver in the fin of the rotor. bent the last one good lol
  11. #11 Re: L/F wheel bearing GP 2008
    Jul 2010
    Coquitlam,BC,Canada
    I've thought about doing it that way. I went uber lazy and bought one of these instead. LOL
    Will be changing the right front bearing AGAIN in a few weeks. Must be the 4th time in about 6 years.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  12. #12 Re: L/F wheel bearing GP 2008
    i got two warranties out of one bought hub, one was defective, the other one well i gave em my old pass side hub lol aka free hub.
  13. #13 Re: L/F wheel bearing GP 2008
    Mar 2017
    Internet
    Just get a friend to push on the brakes and do it.
  14. #14 Re: L/F wheel bearing GP 2008
    Mar 2013
    Canada
    Applying the Brakes Is a good idea, thanks changing it tonight will let you guys know how it goes. The torque​ specs for the wheel hub 3 bolts seems to be 96ft. Does that look accurate?
  15. #15 Re: L/F wheel bearing GP 2008
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by ibra0078 View Post
    96 ft/lbs is correct.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  16. #16 Re: L/F wheel bearing GP 2008
    Mar 2013
    Canada
    Well the wheel hub was so rusted and it took some force to get it out. I had to use heat to loosen the bolts. I tried to use the pulley to push back the axel but it did not want to move at all. Stupid me I forgot to put back the axel nut and hammer that but instead I hammered and hammered the axel shaft itself and now the few first threads are pretty much dented and it's Impossible to get the axel nut back on. Any tricks I can do as I really don't want to get this towed
  17. #17 Re: L/F wheel bearing GP 2008
    Antioch, IL
    Your fcked is the correct answer. You can either A buy a new axle, or B buy the tool that will shave off the end of the axle and your nut will go back on. Google it and find what it is, you did the damage so time to do your homework
    2009 Challenger SRT8
    Expert at being gay.
  18. #18 Re: L/F wheel bearing GP 2008
    May 2016
    Lincoln, Nebr
    You might be able to get away with using a grinder and smoothing the first threads out so you can get the threads started. It'd be a challenge, but it's already f*cked anyway. I guess it's a learning lesson for you, best of luck.
  19. #19 Re: L/F wheel bearing GP 2008
    Jul 2010
    Coquitlam,BC,Canada
    A file or dremel may restore the threads. Being that those threads aren't really necessary, you could grind the first 2-3 thread down until you can get the nut started.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  20. #20 Re: L/F wheel bearing GP 2008
    Mar 2013
    Canada
    It was taking way to long using a dremel so I decided to replace the axel shaft. Replaced it within few minutes and put everything back together and all is good. Thanks everybody for all your help, I guess you live you learn.
  1. shaking steering wheel after wheel bearing replacement
    By vandezand in forum General Tech Discussion
    Last Post: 05-14-2014, 04:02 PM
  2. Wheel rocking still... already changed wheel bearing. Ideas?
    By jmn in forum Introductions/Noob Questions
    Last Post: 09-30-2013, 09:27 AM
  3. 2008 Grand Prix Wheel Bearing/Hub DIY?
    By veener79 in forum General Tech Discussion
    Last Post: 01-27-2013, 07:34 PM
  4. 2008 Grand Prix Wheel Bearing/Hub DIY?
    By veener79 in forum How To Write-Ups/Tech Tips
    Last Post: 01-26-2013, 04:53 PM
  5. ABS wheel bearing/hub on non ABS car?
    By Captain Bravo in forum Brakes/Suspension/Chassis
    Last Post: 01-01-2011, 03:15 PM
