Thread: Brake lights and turn signal - One side only
Results 1 to 10 of 10
  1. #1 Brake lights and turn signal - One side only
    Jan 2013
    Saint John, IN
    My brake light and turn signal on the rear drivers side have gone out. Turn signal lamp in the car and front turn signal blinks rapidly. I have replaced the rear bulbs and no change. I have power to the sockets because the normal tail lights are all OK.
    Based on everything I've read, I'm leaning toward the multi-function switch. Anyone have any quick test to see if this may be the culprit?
  2. #2 Re: Brake lights and turn signal - One side only
    check the bulb socket well, those tails tend to let water in and over time the socket can corrode. that rapid front blinking is what happens when the rear bulb is not seen.
  3. #3 Re: Brake lights and turn signal - One side only
    Jan 2013
    Saint John, IN
    They look pretty good but I'll check them again. Results tomorrow.
  4. #4 Re: Brake lights and turn signal - One side only
    i forget id they are the 3057 bulbs or not, but the push in type the metal bar inside the socket can break, when it does it can break the wire on the bulbs push tab or leave marks on the plastic. had this issue with a front parking and blinker bulb socket, chased it for a while.
  5. #5 Re: Brake lights and turn signal - One side only
    Jan 2013
    Saint John, IN
    Checked all the sockets, cleaned well and added dielectric grease. No change. In addition, service engine light came on this morning. Haven't had a chance to check it yet.
    Another day in the life of a 17 year old GTP owner.
  6. #6 Re: Brake lights and turn signal - One side only
    GT Level Member mguzzo's Avatar
    Buffalo NY
    here's something to check: pull off the passenger tail light assy and check the condition of the wiring on the pass through out of the trunk. There's a bulkhead connector that is all potted up. On my old coupe, my brake lights and turn signals were acting funny. The wires on the bulkhead connector were corroding to the point where I had a sneak circuit, I would step on the brake and the voltage would come back up through the tail light circuit, through the headlight switch, and turn on the fog lamps! I ended up cutting and splicing the wires on the whole taillight / brake wiring harness.
    Take the dielectric grease off, that's OK for high frequency / high voltage (spark plugs) but at 12 volts DC it's an insulator.
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  7. #7 Re: Brake lights and turn signal - One side only
    Jan 2013
    Saint John, IN
    Already had the bulkhead connector and everything looks to be in good shape. Maybe dielectric grease is the wrong terminology. I had a packet of grease that said "Light Bulb Grease".
    Looking at the wiring diagram, there is a yellow wire coming straight form the multifunction switch to the left tail / stop / turn lamp. I will check the voltage in at this point with the turn signal on. Seems like if there is no voltage here the multifunction switch would be the likely culprit.
  8. #8 Re: Brake lights and turn signal - One side only
    Jan 2013
    Saint John, IN
    The socket looked pretty good but I decided for 8.00 I would change it.
    Problem solved. Everything back to normal.
  9. #9 Re: Brake lights and turn signal - One side only
    damn sockets. 8 bucks sounds good to not get tickets.
  10. #10 Re: Brake lights and turn signal - One side only
    Aug 2016
    CT/RI Border
    As a rule of thumb, when you do one, do both, its normally not long before the other starts to go.
    Sent from my ASUS_Z00TD using Tapatalk
  1. Replies: 7
    Last Post: 10-09-2014, 08:43 PM
  2. Brake light and turn signal issue
    By BlackGT97 in forum General Tech Discussion
    Last Post: 07-13-2014, 01:21 PM
  3. 08 turn-signal & brake light issue
    By Dee Johnson in forum General Grand Prix Discussion
    Last Post: 10-03-2012, 02:22 PM
  4. Turn Signal Side Mirrors.
    By bkfelicetty in forum Visual/Body Modifications
    Last Post: 02-03-2011, 03:22 PM
  5. brake lights, cigarette lighter, turn signal wont work
    By dlouis30 in forum General Tech Discussion
    Last Post: 03-03-2010, 10:31 AM
