Thread: Is My Engine On Its Way Out?
Page 3 of 5 FirstFirst 12345 LastLast
Results 41 to 60 of 98
  1. #41 Re: Is My Engine On Its Way Out?
    Jan 2017
    xx
    Sounds similar to my '98 many many moons ago when I spun a bearing at 225k
    https://www.youtube.com/watch?v=QVmJCCUEJz0
  2. #42 Re: Is My Engine On Its Way Out?
    GT Level Member Pursell1911's Avatar
    Jan 2017
    Louisville, Kentucky
    The sound is completely gone now . The car is idling like it normally should. I can rev it in neutral to 3500 rpm's, but when it's in drive it won't go over 2500 RPMs and if I'm going up hills there is absolutely no power. It's almost as if the engine wants to make power but it just can't. The variables just keep changing.
  3. #43 Re: Is My Engine On Its Way Out?
    Jan 2017
    Oh yea, terrible gas mileage too.
  4. #44 Re: Is My Engine On Its Way Out?
    May 2008
    Schuyler, NE
    Did you check the oil to see if it's glittery?
  5. #45 Re: Is My Engine On Its Way Out?
    GTX Level Member cheatah faheatah's Avatar
    May 2016
    Rouge Island
    Your car has a rev limiter in neutral =3500, totally normal. No power up hills, lack of acceleration, bad mileage? Sounds like one of mine that had a clogged cat. Have you tried removing the upstream 02 (oxygen sensor) and then take it for a spin ? If the cat is clogged (like scotty said, think Beverly hills cop) exhaust pressure backs up and limits power. By removing sensor you'd create a new path for exhaust to flow (only for a short spin, not a fix) at least it might tell you where the problem is. Your 02 sensor is where you think it is, you mentioned it when you were working on plugs. Unfortunately, mine got so bad hot gas backed up and melted a hole through my plastic () upper intake manifold...extra costly.
    For the record : I am NOT a naked meth-head who shoves rocks up my butt.
  6. #46 Re: Is My Engine On Its Way Out?
    Jan 2017
    I will check the oil for metal. I've got a new pipe in order so hopefully that will help.
  7. #47 Re: Is My Engine On Its Way Out?
    Jan 2017
    The oil is not glittery. My downpipe should arrive tomorrow, but I'm afraid that won't fix the issue. I'm on the hunt for a vacuum leak because I hear hissing, and my MPG's are really bad, and absolutely no power when above 2k RPM. There's probably lots of issues, just trying to tackle them one at a time. But like I said, no glitter in the oil whatsoever. I can rev the engine in neutral pst 2k rpm, but the engine won't go past 2k when I'm driving. Also, the idle is around 600 or 700 rpm, but every few seconds it lowers a bit, then stabilizes. Probably just need to take it somewhere.
  8. #48 Re: Is My Engine On Its Way Out?
    SE Level Member Monday's Avatar
    May 2012
    Danielleland
    If you rev once and let it drop down quick in a vid we could tell a little more. From the vid you posted, you don't need an exhaust pipe or to pull an o2. Motor is likely history from the sound I am hearing.
    But do that rev vid so we can confirm.
  9. #49 Re: Is My Engine On Its Way Out?
    Jan 2017
    http://www.youtube.com/watch?v=1T0tDFgDymM
  10. #50 Re: Is My Engine On Its Way Out?
    Jan 2017
    Rev
    http://www.youtube.com/watch?v=F7JUBNvYTEo
  11. #51 Re: Is My Engine On Its Way Out?
    Jan 2017
    http://www.youtube.com/watch?v=SsCvb6PJdXg
  12. #52 Re: Is My Engine On Its Way Out?
    I can't car too good. SaukRapids's Avatar
    May 2016
    MN
    There's an electronic throttle on those, like mine.
    I'm sorry, I had a link a long time ago for testing/repair. Having trouble finding it.
  13. #53 Re: Is My Engine On Its Way Out?
    in park open the door stick your foot on the gas pedal and reach around with the phone to the engine, then rev it to 2500 rpm and let the gas pedal drop, leaving the phone under the hood the whole time so we can hear it.
    or just lay the phone under the hood, we cant hear anything to well from inside the car.
  14. #54 Re: Is My Engine On Its Way Out?
    Jan 2017
    Scotty, how bout this?
    http://www.youtube.com/watch?v=c6j6EfpC_ww
  15. #55 Re: Is My Engine On Its Way Out?
    it kinda has that rod knock bounce sound to it. seemed louder the other day. good chance its engine swap time.
  16. #56 Re: Is My Engine On Its Way Out?
    Motor sounds fine, no knocking or anything in that last video.
    The first ones with the loud tapping sound valve train to me, kinda half the speed as the crank with the clatter like a really loud lifter.
  17. #57 Re: Is My Engine On Its Way Out?
    Jan 2017
    FFDP - Would a bad lifter cause the issues I'm experiencing? It's getting worse every day it seems.
  18. #58 Re: Is My Engine On Its Way Out?
    It wouldn't make it this bad. If a lifter bit the dust it would for sure make a constant misfire on one cylinder and it would chug pretty hard everywhere. Check engine light would always be flashing and even with one lifter down it should still rev over 2,000rpm.
    You'd also likely get metal in the oil if it went really bad, it would start chewing the camshaft up or it could just break and bend a pushrod.
    Removing the exhaust is what I would be doing to rule that out, past that through video's I don't it's a rod bearing.
  19. #59 Re: Is My Engine On Its Way Out?
    May 2008
    Schuyler, NE
    This sounds pretty familiar. My 04 comp g chipped a piston, and the debris from the piston clogged the cat keeping it from going any faster than 3k rpms. Being that your oil is clean, your bearings are most likely fine. It's the piston that caused it. And depending on the size of the piston with expansion and contraction, that would cause it to either make noise or not.
    That's what I'm putting my money on anyways.
  20. #60 Re: Is My Engine On Its Way Out?
    Jan 2017
    ok, so to do that, I should remove the two bolts coming off the exhaust manifold(?) and remove whatever bolts are holding the rest of the pipe to the mufflers?
  1. Replies: 10
    Last Post: 07-20-2021, 09:07 PM
  2. 2000 Grand Prix with series 1 Engine, Weirdest engine problem ever!
    By ElectricBlake in forum Introductions/Noob Questions
    Last Post: 01-19-2016, 12:15 AM
  3. Replies: 15
    Last Post: 01-25-2013, 03:05 PM
  4. Check Engine Light - Wont downshift, whine coming from engine
    By brandibissell in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-11-2012, 08:17 AM
  5. Spartans Engine Swap (Engine Damage Pics on Front Page!)
    Last Post: 05-05-2010, 12:50 AM
