Hello together
I'm here since a long time but never posted something.......
Had a problem with my 2000 GP GTP today:
Drove down the highway...at about 80 or 90 km/h I put down the pedal. Car runs, supercharger whines bt then came the service engine light flashing. I released the gas and the light goes off and all was normal. Car runs normal no lights all ok.
At home I take a look for some codes (have an aeroforce gauge)
Codes are:
P0300 and P1441
The first is something with misfire, the second something with the EVAP solenoid
The only thing I did was to install a powerlog. Maybe a problem with this?
Is this a big thing if it goes off and will not came back?
Does someone had the same problems? Maybe the cold winter weather? (Got a GTX hood with RAM air)
Thanks for your answers
02-12-2017
did you remove your spark plugs when you installed the plog? if not go buy new plugs and change em all. cause you cracked one or more most likely.
98 Buick Regal GS, F body brakes, Caddy STS wheels, tinted tails
L36 bottom end, lightly ported heads, 1.95 roller rockers, headers, gen 5 N* 3.0 pulley, FSIC, 42 lb injectors, a BrandonHall rebuilt trans, DHP tuned and AEM water/Meth injection https://goo.gl/gpV5kW
No I didn't only the cables. So why should the plugs be cracked?
Turbo is the way to go.
02-13-2017
Something is causing the P0300 code, so it's likely the plug or wires.
Either they got hit when installing the plog or when you removing the wires they got damaged. I'd start there before jumping to the coil packs or ignition control module.
kappa
just about everyone who does not remove the plugs cracks one or more. they are more delicate then you think, a little tap from the plog and its cracked.
Now I changed the plugs and it runs great ..... thanx!
Post Thanks / Like - 0 Thanks, 1 Likes, 0 Dislikes
03-06-2017
there ya go. lesson learned.
