Thread: Question Codes
Results 1 to 7 of 7
  1. #1 Question Codes
    SE Level Member kappa's Avatar
    Switzerland
    Hello together
    I'm here since a long time but never posted something.......
    Had a problem with my 2000 GP GTP today:
    Drove down the highway...at about 80 or 90 km/h I put down the pedal. Car runs, supercharger whines bt then came the service engine light flashing. I released the gas and the light goes off and all was normal. Car runs normal no lights all ok.
    At home I take a look for some codes (have an aeroforce gauge)
    Codes are:
    P0300 and P1441
    The first is something with misfire, the second something with the EVAP solenoid
    The only thing I did was to install a powerlog. Maybe a problem with this?
    Is this a big thing if it goes off and will not came back?
    Does someone had the same problems? Maybe the cold winter weather? (Got a GTX hood with RAM air)
    Thanks for your answers
  2. #2 Re: Question Codes
    did you remove your spark plugs when you installed the plog? if not go buy new plugs and change em all. cause you cracked one or more most likely.
  3. #3 Re: Question Codes
    Switzerland
    No I didn't only the cables. So why should the plugs be cracked?
  4. #4 Re: Question Codes
    Something is causing the P0300 code, so it's likely the plug or wires.
    Either they got hit when installing the plog or when you removing the wires they got damaged. I'd start there before jumping to the coil packs or ignition control module.
  5. #5 Re: Question Codes
    Quote Originally Posted by kappa View Post
    just about everyone who does not remove the plugs cracks one or more. they are more delicate then you think, a little tap from the plog and its cracked.
  6. #6 Re: Question Codes
    Switzerland
    Now I changed the plugs and it runs great ..... thanx!
  7. Likes mrbreezeet1 liked this post
  8. #7 Re: Question Codes
    there ya go. lesson learned.
  1. Codes C0050 & C0060 Question
    By Sash in forum General Tech Discussion
    Last Post: 09-07-2016, 08:50 PM
  2. Need help with codes
    By skippy in forum Introductions/Noob Questions
    Last Post: 04-13-2013, 12:34 PM
  3. got some codes need help
    By buschegt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-22-2012, 06:20 AM
  4. codes codes codes gotta love them!
    By 19GTP98 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-31-2012, 02:13 PM
  5. P0137, P0327 codes question
    By GTLGDP in forum General Tech Discussion
    Last Post: 12-16-2011, 03:38 PM
