It should work fine. Are you asking which color wires from the car to splice, or just a switch like that in general? It's a four pole toggle with illumination. Uhh..the last one I wired had opposite poles. It kinda looked like this.
I wired one common ground. The power for the lights get put on the (+) sides, then both the device and light on the switch received power when the switch was closed (on). That's how I got mine to work, anyway. No idea if that's the "right" way, lol.
I went out and looked at it. It's a switch from Radio Shack, iirc.
A continuity tester on the switch will help figure out what the wires are.
Edit: Mine's illuminated all the time in the garage. I don't think you'll need a jumper in there just for the lights.
