Thread: 2001 GTP surging / stumbling plus check engine light
Results 1 to 17 of 17
  1. #1 2001 GTP surging / stumbling plus check engine light
    Chicago
    Hello. My GTP has around 160k miles on it. I have owned it since 2006. I have a triple whammy going on. The check engine light came on about 2 weeks ago. I am getting a P1404 code. I tried resetting the codes but it immediately came back. A few days ago, the car has started surging while driving. I notice it mostly at speed on the highway and under light acceleration. I don't seem to notice anything under hard acceleration. Last week I also got a recall notice (15757) for a potential under hood fire.
    Could the EGR code be related to the surging or do I have another issue going on with the transmission? I did a trans service around 100k.
    Btw, I pulled the EGR out last night and the pintle seemed to move freely. I put the EGR back in and disconnected the battery. I cleared the code as well. About 15 minutes into my drive this AM the code came back. The car was surging still at speed and under light acceleration.
    Any thoughts?
  2. #2 Re: 2001 GTP surging / stumbling plus check engine light
    ever tune it up?
    and you need a new egr, or take yours off and try to clean it. i have no egr at all. so if its stuck shut its not hurting a thing .
  3. #3 Re: 2001 GTP surging / stumbling plus check engine light
    Chicago
    ever tune it up?
    Yes. Wires, plugs and pcv around 100k. The EGR was replaced with an aftermarket one around the same time for the same code. No driveability issues back then though.
  4. #4 Re: 2001 GTP surging / stumbling plus check engine light
    what plugs you install? might be due for another, hard to say. check fuel pressure for the hell of it too.
  5. #5 Re: 2001 GTP surging / stumbling plus check engine light
    Chicago
    I installed original OEM plugs and wires. No mention of a trans problem yet. Can I rule that out at this point? If ordering a new EGR, would you go with an aftermarket one or should I get an AC Delco one this time around?
    Also, when I replaced the EGR originally due to the same code, the check engine light remained on even after resetting the codes. It wasn't until I had a battery issue that it went away. Is it standard practice to disconnect the battery after replacing an EGR valve? I read somewhere that closed position is not reset until the battery is disconnected.
  6. #6 Re: 2001 GTP surging / stumbling plus check engine light
    it could be bad wires to the egr too. inspect them for damage, cracks or bare wire.
    if the engine feels like its crapping out the trannys good.
  7. #7 Re: 2001 GTP surging / stumbling plus check engine light
    Chicago
    Could there be an issue with a bad throttle position sensor or IAC? I drove home tonight and after about 15 mins and I noticed the stumbling or surging behavior at cruising speed and light acceleration. The behavior is very consistent now after the car warms up. I also checked my receipts and I replaced the EGR 2 years ago. It was a Standard Motor Products EGR valve. 2 years and it is already bad???
  8. #8 Re: 2001 GTP surging / stumbling plus check engine light
    Mar 2016
    Sounds stupid but check to ensure that you have 2 orings on the PCV valve. Had very similar symptoms and that was the cause. I was missing the bottom oring
    Sent from my SAMSUNG-SM-G891A using Tapatalk
  9. #9 Re: 2001 GTP surging / stumbling plus check engine light
    Apr 2014
    Michigan
    Quote Originally Posted by mababel05 View Post
    Sounds much like an ignition problem. Check both plugs and wires. If they are good ohm ignition coils.
  10. #10 Re: 2001 GTP surging / stumbling plus check engine light
    Jan 2013
    Saint John, IN
    Don't go aftermarket on the EGR. I fought this battle for about 1 month until I replaced it with one from Carquest. Light went off and stayed off since last May.
  11. #11 Re: 2001 GTP surging / stumbling plus check engine light
    Oct 2013
    michigan
    My pos zzp coils did this in the middle of a snow storm couple weeks ago. Reinstalled the oem coils and all was resolved. Though I did have misfire codes and not the one the op listed.
    01 gtp SD headers. gen V swap. hai. zzp 1.0 pcm. 06 Impala brakes. GMPP sway bar.
    01 ram 2500 870hp/1796lbft fmw s467.7 w/n20 old. new 66/86 compounds ????hp/????lbft.
  12. #12 Re: 2001 GTP surging / stumbling plus check engine light
    Chicago
    Well apparently I have a trans problem. This morning I started driving to work and I felt the trans slipping. This happened roughly 2 blocks from my place. I immediately turned around and barely made it back to my place. I did not make into my garage and had to push it back into a parking spot. It does not move in any of the gears.
    Btw, I called up Triple Edge Performance and they believe torque converter (including clutches) went out and the trans will most likely need to be rebuilt.
  13. #13 Re: 2001 GTP surging / stumbling plus check engine light
    well thats the worst case possible right there.
  14. #14 Re: 2001 GTP surging / stumbling plus check engine light
    Chicago
    Yeah, tell me about it. According to the conversation I had this AM with TEP, I should consider 163k a lot of mileage on an original GTP transmission.
    Now I need to decide whether I want to invest that much money in this car. I am considering how much it is worth as is now vs. after it is repaired. If I fix it to keep it for a few more years what other problems are lurking?? We'll see...
  15. #15 Re: 2001 GTP surging / stumbling plus check engine light
    i feel ya, i just installed a new tranny 120 miles ago, 1400 bucks shipped from a member here who rebuilt it. look at it this way, a new car will cost more then the tranny will. and you know this car already. unless your just ready to toss in the towel, swap the tranny.
  16. #16 Re: 2001 GTP surging / stumbling plus check engine light
    Chicago
    A friend of mine just recommended a shop who has quoted $1300 to rebuild the transmission. Supposedly they normally charge $1700 and that is with a discount. I am not sure if "rebuilding" implies a standard procedure but I am guessing $1300 will just fix what's wrong vs. replacing all wearable parts. Not sure what else is done above and beyond by a dealer or a place like TEP on their rebuilt transmissions. If I go the TEP route, I am looking closer to $3000 - $3500 assuming I find a shop willing to just replace a trans if one is shipped to them.
    On a side note, I would like to take on a project like this myself but it is winter time and I no longer have a garage to do repairs or the time to do them.
  17. #17 Re: 2001 GTP surging / stumbling plus check engine light
    most of the time a trans shop will only fix it, not replace everything that would make it a full rebuild. tep you getting new everything but some reusable parts.
    they got a back to basic tranny for stock set ups for like 1500 i think.
    this is all thats replaced in my tranny http://www.grandprixforums.net/threa...-1100-cash-OBO
    be hard pressed to find a shop thats going that far. but a tep tranny would be very much like the list in this link ^^^
  1. Flashing check engine light and Low oil light?
    By Explicit_Spade in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-14-2016, 01:54 PM
  2. Engine Light on code P0171, IDLE SURGING!
    By balzi in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-07-2013, 01:51 PM
  3. Check Engine Light - Wont downshift, whine coming from engine
    By brandibissell in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-11-2012, 08:17 AM
  4. check engine light and lose wire in engine bay
    By Fcukit33 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-13-2011, 05:29 AM
  5. Surging Through Low Speeds and No Check Engine Light
    By NapNinja317 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-15-2010, 11:06 AM
