Thread: key fob restart 2008 gp
Results 1 to 2 of 2
  1. #1 key fob restart 2008 gp
    Dec 2016
    michigan
    Hi all I have a question about remote start. have a 2008 gp with new fobs that were programed recently. I had a check engine light I resolved so the fobs would start the car. here's the thing. the car will start with the fob however if you hit that same button to stop the car it then disables the remote start. you even see that up on the display on the I/p. once you then start and stop it with the key that resets it and will work again. I haven't let it run its cycle and try to remote start it again to see if I get a second chance at it. I thought that most if not all cars gives you 2 chances to start with the fob regardless how the car is shut of the first time. is this normal on this vehicle?
    thanks
  2. #2 Re: key fob restart 2008 gp
    SWPA
    You should be able to restart it once more after shutting it down with the FOB, or letting it run 10 minutes before it shuts itself off.
  1. 2006 GP 3.8 NA Stalls Hard Restart
    By AK47GP in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-13-2014, 06:17 PM
  2. Replies: 8
    Last Post: 12-19-2013, 07:09 PM
  3. NEED HELP! 94 grand prix will only restart after waiting
    By cosmoe in forum General Tech Discussion
    Last Post: 07-15-2012, 07:22 PM
  4. 97 GTP runs (sometimes) Spits and sputters, then won't restart
    By RedIrocZ28 in forum General Tech Discussion
    Last Post: 04-12-2011, 09:16 AM
  5. 98 gtp engine stall restart dies
    By troubled in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-07-2009, 05:57 PM
