Thread: 2001 grandprix gt p0446 code..no converter but no P0420 code...
Results 1 to 2 of 2
  1. #1 2001 grandprix gt p0446 code..no converter but no P0420 code...
    GT Level Member chicagochuck's Avatar
    Aug 2012
    Chicago
    Chats
    2001 grandprix gt
    It had a po420 code about 2 yrs ago, I put in a oxygen sensor pipe entender and the code went out. I also had the resonator removed eventually when it went bad.
    I sold the car to a family member oct 2015... In may of 2016 the straight pipe where the resonator/straight pipe was welded to the downpipe cracked. SO I told him to go get a straight pipe re welded where it was originally attached
    Fast forward to today I'm working on the car trying to figure out the po446 , I changed the vent valve but code still remains. I also noticed that the exhaust is stronger than I remember. I get under the car and the converter is gon as well, its straight piped all the way to the mufflers. crazy things is its not throwing a p0420 code at all.
    I guess i should have went with him to the exhaust shop, not sure if it'll be a problem but Im sure thats not what he really wanted done.
    Didn't think that would be possible to not throw the 420 code. Just wanted to share that story
  2. #2 Re: 2001 grandprix gt p0446 code..no converter but no P0420 code...
    SE Level Member khornocker's Avatar
    Jan 2016
    Corydon, Indiana
    Chats
    regarding the P0446 code. is it hard to put gas in the car. I had the same code for a while but I couldn't fill my tank, when I changed the vent valve it didn't fix my issue. my problem ended up being my charcoal canister that's mounted on top of the gas tank.
  1. hard to fill up gas tank and P0446 code
    By khornocker in forum General Grand Prix Discussion
    Last Post: 10-22-2016, 11:32 PM
  2. P0446 code
    By willie14 in forum General Tech Discussion
    Last Post: 10-06-2016, 08:10 AM
  3. code P0446
    By vagk1234 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-01-2013, 10:08 PM
  4. How to get around P0420 code?
    By dmahlikGT in forum PCM Tuning
    Last Post: 08-29-2013, 12:43 PM
  5. P0420 Code keeps setting on 2001 GTP
    By Littlegiant in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-06-2008, 07:50 PM
