Thread: rear brake pad issue
Results 1 to 4 of 4
  1. #1 rear brake pad issue
    SE Level Member khornocker's Avatar
    Jan 2016
    Corydon, Indiana
    hello, im having a rear brake pad issue on my 2005 GTP.
    I am only getting about 5 weeks out of my rear pads before they are worn down to the metal backing plate. its only the inboard side pad but its happening on both the drivers and passenger side of the car. the outboard side pads will still look brand new. the caliper slide pins are good, clean and well lubed. I don't expect my calipers are bad just for the reason that's its happening on both sides of the car. what about my master cylinder or power booster? I do have a random misfire that a vacuum leak at the booster could cause. any thoughts would be great.
  2. #2 Re: rear brake pad issue
    SWPA
    I would say either the e-brake cable is sticking, or your hoses are partially collapsed.
  3. #3 Re: rear brake pad issue
    GT Level Member brettstoner's Avatar
    Jul 2014
    Toledo, OH
    Are the front brakes working? Do they feel warm? Do the back brakes feel really hot? Smoking even? Sticking?
    If you install the caliper without pads does it slide freely back and forth?
    Is the e-brake applying any pressure?
    04 GP GT- top swap, VS cam, 2.8 pulley, E85, headers, 60 injectors, TEP 3:29 trans, Racelogic Traction Control, ZZP dyno tuned.
  4. #4 Re: rear brake pad issue
    Jan 2016
    Corydon, Indiana
    The front brakes are fine and show normal wear. and yes the back brakes will burn the crap out of you after my 45 min drive to work. I'll have to see if the calipers slide freely without pads
  1. 2005 Grand Prix GTP Rear Brake Issue
    By whitefeathersnpr in forum Brakes/Suspension/Chassis
    Last Post: 08-24-2012, 07:40 AM
  2. E brake issue
    By illy in forum General Grand Prix Discussion
    Last Post: 07-27-2012, 05:23 PM
  3. 95 GP brake issue
    By jgrant517 in forum Brakes/Suspension/Chassis
    Last Post: 05-07-2010, 10:37 AM
