Thread: Interior swap
Results 1 to 7 of 7
  1. #1 Interior swap
    Aug 2015
    Virginia
    Going to the junkyard on Saturday and swapping the interior from a wrecked Grand Prix into mine. My questions are can I get the factory heated seats to work if I move the AC module and can I get the sensors and harness to make my car have auto AC? If you can direct me to how to do this that would be greatly appreciated.
  2. #2 Re: Interior swap
    GT Level Member mguzzo's Avatar
    Buffalo NY
    what year? for 97-03, if you have manual controls you can't switch over to the auto climate control. if you have power drivers seats you might have the harness for the heater, you'd have to check in the center console for the switch pigtail.
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  3. #3 Re: Interior swap
    Aug 2015
    Virginia
    My car is an 05 and everything is coming from an 07
  4. #4 Re: Interior swap
    I'm sure you can wire in the heated seats but switching from manual climate control to full auto climate control is never that simple.
    The whole cars interior harness is somewhat different and the BCM programming is all different. I'm pretty sure it's just like the 97-03 body style, you won't be able to just plug in and go with that stuff.
  5. #5 Re: Interior swap
    Aug 2015
    Virginia
    I only asked because the donor car has it on the climate controls so I would need that to get the seats to work I thought.
  6. #6 Re: Interior swap
    Aug 2015
    Virginia
    Sadly one of the seats has a huge gash in it now, don't know why people do that ****.
  7. #7 Re: Interior swap
    Nov 2015
    missouri
    Easy to change the cover on the seat if you can find a good one
    Sent from my SM-N900T using Tapatalk
  1. 04+ interior/seat swap in 97-03
    By Tyarne15 in forum Visual/Body Modifications
    Last Post: 05-28-2015, 03:51 PM
  2. Interior Swap? GT to SE?
    By Brian99SE in forum Visual/Body Modifications
    Last Post: 02-26-2012, 11:47 AM
  3. interior swap
    By gtcoup in forum Visual/Body Modifications
    Last Post: 12-14-2011, 02:34 AM
  4. newer generation interior swap and SE spoiler
    By comongoose in forum Visual/Body Modifications
    Last Post: 02-09-2009, 09:17 PM
