Thread: zzp shift kit
Results 1 to 20 of 22
  1. #1 zzp shift kit
    GT Level Member willie14's Avatar
    Jun 2016
    westland mi
    Does anyone have any pictures of how the shins go into the accumulator. All the writeups I've found are for the transgo and its a little different. I've got new springs that obviously didnt come with zzps kit but id like to see if and how anyone else placed there shims on the pistons before I just go and throw it in...
    Now I know everyone thinks zzps kit Is crap but I work with huge accumulators for a living and we shim with UHMW poly similar to zzps shims because its easier on the piston shaft instead of stainless or aluminum. I feel if zzp offered more with the kit it would be better.....anywho, photos would be nice...
    98 Grand prix SE to GTP conversion( in works). Full body conversion in works, drilled n slotted rotors, ceramics, all new suspension, custom CAI, NGK wires/Vpower plugs, SD headers, 180 Tstat, AND A WHOLE BUNCH OF PAINT BABY!! Tuned by E&J performance.
  2. #2 Re: zzp shift kit
    Dec 2013
    Enfield
    ZZP offers no instructions with their kits?
  3. #3 Re: zzp shift kit
    Jun 2016
    westland mi
    They do but they're just kinda crap. They say they got a shift kit write up with photos clearly in the directions, but when I emailed they're customer service that just kinda hack around the answer your looking for and don't tell you nothing useful.
  4. #4 Re: zzp shift kit
    Dec 2013
    Enfield
    Tell them to send you a clear copy, show them a pic of the kit if need be. I really have no love for ZZP, while crucial to the platform as a aftermarket resource, too many horror stories about failing parts or poor customer service.
    https://s3.amazonaws.com/zzpstorage/...structions.pdf
  5. #5 Re: zzp shift kit
    Jun 2016
    westland mi
    As you can see in those directions it clearly says pictures
  6. #6 Re: zzp shift kit
    Jun 2016
    westland mi
    Yea I did, all they keep tellin me is just read the directions and shim per what it says.
  7. #7 Re: zzp shift kit
    I can't car too good. SaukRapids's Avatar
    May 2016
    MN
    Send them a picture of your direct assumed setup. Title with "Is this right?"
  8. #8 Re: zzp shift kit
    Jun 2016
    westland mi
    You talkin about a photo of the accumulator after I shim the piston shafts? Lol only prob with that is id have to wait half the day to respond to my email
  9. #9 Re: zzp shift kit
    May 2016
    MN
    That's what I'd do, honestly. Sucks waiting, but there was a thread on here; guy needed a spring and didn't wait. I think it blew up because I haven't seen a "Need urgent help with rebuild!" thread yet.
    You could post a picture here. Maybe someone can say if it looks right, but I used a different kit.
  10. #10 Re: zzp shift kit
    Jun 2016
    westland mi
    Yea I remember seeing that, but that was when he pulled the accumulator apart and the smaller spring was broke. I havnt done the kit yet but I imagine that happening is pretty rare
  11. #11 Re: zzp shift kit
    May 2016
    MN
    My final thought when I put my accumulator back together; "I wonder if I even need the shims and spacers with the spring placement I used (trans-go). Actually, if they're moot, they might just be adding wear to the guide/pin thing."
    I've read that zzp used different material shims to ease the wear, but again, I don't have one. I read through the instructions and am now guessing that you don't have the accumulator removed yet. That's not a problem. Describing what I read, when you get out, the pots are marked with 1-2 & 2-3 on one side of the housing. Keeps the pistons positioned correctly, I didn't and had to use a pic. Remove the piston in 1-2 and place in the desired length shim per their suggestion; 3/4" shims in the pot under both pistons, then a third 3/4 on top of the piston in the marked pot 2-3. Finally, top the 1-2 piston with a 1/2" piece.
    They say you can use whatever combo, but I'd start with that. If it's not what you're looking for, better get a pan with a drain plug.
  12. #12 Re: zzp shift kit
    Jun 2016
    westland mi
    The shims they use for their kit are the same material I use at work on our larger accumulators to ease transition of initial fluid pressure. Its alot easier on the housing and the shaft instead of using stainless
  13. #13 Re: zzp shift kit
    Jun 2016
    westland mi
    I did lol, I went and bought a new pan for when I do the fluid filter swap and shift kit install
  14. #14 Re: zzp shift kit
    Jun 2016
    westland mi
    So I got the shift kit and custom springs installed in my trans. Took me about 3 1/2 hrs to do it because I had to drain the fluid into this small tiny pan I had so that took forever and the new pan I bought ended up being the wrong size so I had to clean up the old one and reinstall but I am super happy with the results. I ended up using springs from my work that we use for our hydraulic manifolds instead of using the stock springs so it didnt cost me anything else. I ended up matching the stocks to a set of beefier springs that were a slight bit stiffer under compression. First shift kit install, but I got say it was a success! She shifts on a dime now��
  15. #15 Re: zzp shift kit
    May 2016
    MN
    Glad you got it in there. If you'd ever want to change the shims or anything, I got this at Home Depot for $5. Better than a tiny one drain pan, Lol
    https://www.google.com/search?q=home...mess+drain+pan
  16. #16 Re: zzp shift kit
    Jun 2016
    westland mi
    Yea I was gonna go out n buy one but I got too ancy and wanted to install. New springs & UHMW shims worked out great! Shoulda took pics tho. I dont see any writeups for zzps kit but I imagine that's because it doesn't come with nada. Crappy bout the pan I bought too. I guess ill put the right one on when I do another trans flush. What's the milage everyone's getting between trans flushes? Curious....
  17. #17 Re: zzp shift kit
    May 2016
    MN
    The papers in mine showed one at 79k from previous owner. I just did it again at almost 140k.
  18. #18 Re: zzp shift kit
    Jun 2016
    westland mi
    So I'm basicly lookin at 50-75 K miles between fluid changes...doesn't sound too bad but maybe refresh the fluid sooner then that or is I not good to constantly do trans fluid changes like your oil changes?
  19. #19 Re: zzp shift kit
    Jul 2010
    Coquitlam,BC,Canada
    Check your fluid and change it if it isn't red.
    I change my fluid several times per year; during the summer months I see a lot of 200*+ temps.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  20. #20 Re: zzp shift kit
    Jun 2016
    westland mi
    So I doesn't hurt it by constantly changing it then? I seen on one thread/ writeup where the guy said to always mix son of your old fluid in with thenew but I figure that since there's about what 4 quarts that doesnt come out thru the pan, you'd just have that to mix with the new....I know everyone's got their own preferences on how they do things...
  1. Tranny Issue help! 1st shift is slipping/sluggish.2nd and up real quick jerk shift
    By Prixness in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-26-2014, 12:28 PM
  2. zzp shift kit or intense shift kit
    By ScammingL67beast in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-19-2013, 10:50 PM
  3. Which shift kit to get?
    By rhenuset in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-05-2013, 01:29 PM
  4. Replies: 1
    Last Post: 12-08-2012, 07:39 PM
  5. Wot pop/cut out at shift
    By DaytonaGTP500 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-03-2012, 12:59 PM
