Thread: Replaced fuel sender now fuel leak.
Results 1 to 4 of 4
  1. #1 Replaced fuel sender now fuel leak.
    SE Level Member smg267's Avatar
    Apr 2016
    killadelphia
    I just spent the better part of 3 hours ripping apart two grand prixs to make one functional gas gauge. The rubber o ring was an absolute nightmare trying to keep up when placing the fuel pump back in. I just went to fill the car and it was hemorrhaging gas from above the tank. I know I am going to have to take this apart again, are there any secrets to keeping the o ring at the top of the pump? I was thinking of just using RTV.
    Also, any harm in driving the car like this until I get it below half a tank?
  2. #2 Re: Replaced fuel sender now fuel leak.
    GT Level Member WickedGoat's Avatar
    Dec 2014
    Missouri
    I wouldn't drive a car with leaking fuel... only takes 1 asshole with a lit cigarette or something else and...... Are you dropping the tank from the bottom of the car or are you going through the trunk to the fuel pump access cover? (Assuming this is a 97-03, don't know if 04+ have the access in the trunk) Either way, the complete fuel module should close tightly to the tank with the rubber O-ring sitting in place properly. You should not need RTV to hold the o-ring secure. Should be grooves to properly secure it with. I am going by memory here since I have not done a w-body fuel pump in a while. Make sure the retainer c-clip is installed properly also as this will cause a leak if it isn't.
    edit - https://www.youtube.com/watch?v=rk-c0ni41tc
    edit again - http://www.intense-racing.com/walbroinstall.shtml
    2014 Chevy Impala LTZ Limited -- Silver/Black, Grand Prix replacement
    2004 Pontiac GTO -- my garage queen
    2004 GMC Yukon SLT -- wife's daily driver
  3. #3 Re: Replaced fuel sender now fuel leak.
    lube the o ring with Vaseline or grease, then install it and the pump. they tend to fall off and push through if not lubed up.
  4. #4 Re: Replaced fuel sender now fuel leak.
    Apr 2016
    killadelphia
    Pulled the entire assembly apart only to find a pinched O ring. I bought a new replacement at Advanced Auto and spent the better part of 2 hours and a can of vasoline trying to get it to seal. My friend that is a mechanic had it seated in 20 minutes. The new O ring was impossibly difficult to compress.
    Thanks for the help!
  1. Fuel gauge sender
    By Freddy in forum For Sale - Parts
    Last Post: 07-02-2013, 02:40 PM
  2. fuel sender
    By camarozz383 in forum Wanted To Buy - Parts
    Last Post: 06-24-2013, 03:27 PM
  3. fuel sender issue
    By dlz47 in forum General Tech Discussion
    Last Post: 08-11-2011, 12:12 PM
  4. Fuel sender - need to replace?
    By Skrappi69 in forum General Tech Discussion
    Last Post: 04-06-2011, 02:44 PM
  5. Fuel pump / Fuel sender question !
    By 2001redfireGT in forum General Tech Discussion
    Last Post: 03-01-2010, 11:03 AM
