Thread: Boost level expectation?
Results 1 to 7 of 7
  1. #1 Boost level expectation?
    SE Level Member Centauri's Avatar
    Sep 2014
    St. Paul, MN
    I've searched but am not seeing any results.
    Basically, I'm wondering what level of peak boost I should expect to read at WOT. Set up is Reptile tune, 3.4 pulley, headers...
    Highest I've seen flash at me, scanning with Torque, is right about 8lbs. For most of the pedal mash boost is in the 6 to 7 range. Isn't that low for a 3.4?
    Also looking to do a pulley drop since knock looks in order. What should a 3.2 achieve?
    Thanks guys.
    Sent from my LG-H811 using Tapatalk
    1999 Grand Prix GTP sedan
    Speed Daddy headers, 3.25" on a ZZP MPS, high-flow cat, 180
    ° t-stat, Autolite copper 104s, shift kit, ReptileTune...
  2. #2 Re: Boost level expectation?
    i used to make about 10 in the summer and 12 in the winter on a 3.4 with rockers. you wont see the max boost # till your red line the rpms. aka at the shifts.
    so you might be a bit low, maybe the bbv needs to be adjusted, or your cars a freak and flows very well.
    kr in check means? no kr or a little bit of kr? that 3.4 is typically the wall unless you have a cam or more flow mods.
    my mod list in my sig nets me 8 psi. im on a 3.2 pulley now.
  3. #3 Re: Boost level expectation?
    Sep 2014
    St. Paul, MN
  4. #4 Re: Boost level expectation?
    so a blip at the shift from what i can see. timing looks stock. you might get away with a 3.3
  5. #5 Re: Boost level expectation?
    Kemmerer, Wyoming
    there are a lot of variables that go into boost. by definition, boost is the presence of restriction inside an engine. with that being said, more boost does not always mean more power. I live at 7000 feet elevation, and I am lucky to see 8 lbs of boost on a 3.0" pulley. so it's hard to say if your car is making the boost that it should. you could check your bbv and push it down, if possible, that by itself can make 1 more lb of boost of it's not adjusted right.
  6. #6 Re: Boost level expectation?
    Sep 2014
    St. Paul, MN
    So with regard to Torque's accuracy: how accurate is it generally considered to be with things like KR?
    I ask because the last time I did a KR read with BrandonHall in Tucson using HPtuner, I had more occurrences of KR than Torque showed from my read last night.
    Not sure how much of that is Amarillo being 1300ft higher than Tucson was though?
  7. #7 Re: Boost level expectation?
    its accurate, shows the same data as my dhp scans.
  1. Low Oil Level Light Still Comes On After Low Oil Level Sensor Replacement
    By LoveMyGPGT in forum General Tech Discussion
    Last Post: 04-23-2017, 09:20 AM
  2. Low boost, block off boost bypass solenoid. Full boost returns..
    By TexasTanker19kilo20 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-23-2016, 11:14 AM
