Thread: Help!
Results 1 to 3 of 3
  1. #1 Help!
    Aug 2016
    Colorado
    2004 Grand Prix gtp...replaced fuel pump And fuel filter still no start..it will turn on for about 10 seconds and then die out. Does anyone know what the problem could be??!!
  2. #2 Re: Help!
    Do you have another key you can try to rule out the security system.
  3. #3 Re: Help!
    we just had a guy with the same issue, his turned out to be a loose ground wire to the body of the car near the battery. check all grounds and clean the battery terminals up too.
