Thread: gt vs gtp
Results 1 to 3 of 3
  1. #1 gt vs gtp
    Jul 2016
    Butler
    what all would i need to change to put the supercharger on the GT? is it all the same as the GTP minus the supercharger?
  2. #2 Re: gt vs gtp
    GTX Level Member Travisgt2's Avatar
    Jan 2013
    leavenworth ks
    You would need a good tune you would need the heads you need the lower intake manifold you need the supercharger you need the PCM but you can't just run a stock PCM you would end up blowing your motor up you have to have somebody tune it with a specific tune for you. Me and another guy on here with a Impala that's heavily modified can beat stock supercharged cars your best bet is to run your n/a setup but from a 04 or newer and run a turbo if you really want Power but if you're going to go that route you're going to want to run a supercharged bottom end because compression. It's all in money and route you want to go. I'm trying hit 300hp on a n/a set up that's my goal
    04 GT2: 180 t-stat, cold air intake, reptile tune, plog, hv3, gt1 cam, 90#springs, new push rods, new lifters, port polished heads, lim, uim and tb, 06 Impala brakes and steel brake lines. Cosmetic: black roof rails, under glow, Pontiac ground light, blue hud dic radio controls and cluster. To come custom hood.
  3. #3 Re: gt vs gtp
    http://www.grandprixforums.net/threa...s-of-3800-Info
    Read that, then read more on this topic. Been covered a few million times by now.
