Thread: How to remove roof rails ??
Results 1 to 16 of 16
  1. #1 How to remove roof rails ??
    SE Level Member 01grandpri's Avatar
    Oct 2015
    allendale michigan
    Hey guys just got a parts car 40th anniversary..how can I remove the roof rails without damaging them??
  2. #2 Re: How to remove roof rails ??
    GT Level Member Jnibbs24's Avatar
    Sep 2015
    Seattle
    Pry up from the rear but go slow so you don't warp them, best to let sit in sun all day. Then to remove your stock ones do the same but don't be as gentle no way in hell you're saving those....!
  3. #3 Re: How to remove roof rails ??
    Jan 2014
    AR
    I like to use a snap knife for things like that. To cut the attachment tape. Pry gently, cut a little, work slowly.
  4. #4 Re: How to remove roof rails ??
    Nov 2011
    NY
    Hair dryer and dental floss? Lol
  5. #5 Re: How to remove roof rails ??
    Oct 2015
    allendale michigan
    Heat gun and pry slowly ?? Ahaha think maybe that should work?
  6. #6 Re: How to remove roof rails ??
    Nov 2011
    NY
    Quote Originally Posted by 01grandpri View Post
    be real careful with a Heat Gun... They have a lot more heat then a hair dryer and can do damage. The rails are not metal...
  7. #7 Re: How to remove roof rails ??
    Oct 2015
    allendale michigan
    Okay, I'll try hair dryer first and go from there..so start from the back then?
  8. #8 Re: How to remove roof rails ??
    Mar 2012
    NC
    Take a putty knife, bend it 90* in a bench vise, then grind it to a 1/2" size triangle. Sharpen like a knife. Stick it under the back of the rail and wiggle the knife. It'll cut right through the double sided tape. I feel bad for anyone that finds the set I put on...windshield urethane was used.
  9. #9 Re: How to remove roof rails ??
    Oct 2015
    allendale michigan
    Oh yeah that's the next question lol what can I use to stick them on my car?
  10. #10 Re: How to remove roof rails ??
    3m double sided tape
    Sent from my KYOCERA-C6745 using Tapatalk
    04 Comp G.
  11. #11 Re: How to remove roof rails ??
    GTP Level Member mrlogic1234's Avatar
    Jul 2010
    Detroit
    They are just held on with tape. Take a flat head to the front by the windshield and gently pry up. You should be able to remove them by hand at that point.
    Ryan
    2000 GTP Coupe Green/Grey - SOLD!
    2008 GXP Black/Ebony
  12. #12 Re: How to remove roof rails ??
    Oct 2015
    allendale michigan
    Thanks guy for all the info! My 40th parts car is sittin in the garage waiting to be torn down lol if you know of anyone wanting a 3800 n/a 180,000 miles or 40th interior just send them my way
  13. #13 Re: How to remove roof rails ??
    May 2016
    Tampa, FL
    To be an echo in the room you'd want to go from end to end wiggling on it and find where it's most loose and find small flat object, I used a small screw driver, and very carefully wiggle the screw driver in a prying motion and it should come up at that point a little, then you carefully pry the rest of it off making sure your not warping the plastic as it comes off. It is only held on by some double sided tape so minimal force is necessary. Hope this helps.
  14. #14 Re: How to remove roof rails ??
    Oct 2015
    allendale michigan
    Update! Got them off, let it sit in the sun for a while and just a screw driver and slowly and very carefully pulled them up
  15. #15 Re: How to remove roof rails ??
    Mar 2014
    New Orleans
    Are you selling them ??
  16. #16 Re: How to remove roof rails ??
    Oct 2015
    allendale michigan
    No
  1. SOLD Roof Rails (photos added of rails)
    By 7801MonteMan in forum For Sale - Parts
    Last Post: 04-13-2014, 09:38 PM
  2. How to remove Anni Roof Fins?
    By K Dawg ONE in forum Visual/Body Modifications
    Last Post: 01-12-2011, 12:50 PM
