Thread: Transmission At Idle
Results 1 to 7 of 7
  1. #1 Transmission At Idle
    SE Level Member themantis's Avatar
    Mar 2016
    So I have a 99 GTP and have started to notice that after I start my car, shifting to reverse sounds like a clunk with a metallic tone in it and shifting to drive just clunks. Also, if I'm in gear and release the brake, I don't roll forward or back until I depress the accelerator.
    My initial thought was a worn or loose torque converter, but after some research it looks like the converter would have different symptoms. Any help would be appreciated ☺
    -theMantis
  2. #2 Re: Transmission At Idle
    I would be checking over all suspension related parts and motor mounts for the clunk.
    And maybe a dragging caliper/pad for the rolling part.
  3. #3 Re: Transmission At Idle
    Mar 2016
    Good idea about the calipers, but why would suspension be related? Regardless, I just replaced the front control arm bushings and rear sway bar links myself, nothing else looked to bad
    -theMantis
  4. #4 Re: Transmission At Idle
    St. Louis
    Did you check the engine and trans mounts? How are the bushings in the dogbones up top?
  5. #5 Re: Transmission At Idle
    Mar 2016
    Quote Originally Posted by FordMan77 View Post
    You were right, I brought it in for a recall recently and the dealership forgot a nut for the bolt holding the dog bones. Thanks bud
    -theMantis
  6. #6 Re: Transmission At Idle
    St. Louis
    Good deal. I like easy/cheap fixes.
  7. #7 Re: Transmission At Idle
    Mar 2016
    Retweet. I went to a pull your part yard yesterday and got a replacement driver side skirt, mirrors, and many small fixes for less than $15. And clean pre-gen rims are $25 each
    -theMantis
  1. P0171 and P0300 Codes, Mildly Rough Idle, Rough on starts, Slightly Elevated Idle
    By nskyline34 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-17-2021, 07:49 PM
  2. 01 GP, won't idle and now transmission won't shift? HELP
    By ARFF22 in forum General Tech Discussion
    Last Post: 08-14-2013, 06:19 PM
  3. Rough Idle with intermittent idle miss
    By 99GTPMLA in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-09-2012, 12:12 PM
  4. Running rich at idle, causing idle issues.
    By matt5112 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-22-2010, 09:16 PM
  5. High / Fast Idle - Idle Air Control motor?
    By porshuh in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2009, 11:28 AM
