I have fuel pouring from my gas tank, ive siphoned enough to slow it. Where do i order a fuel tank fuel pump fuel filter and filler neck? I saw these items sold as an oem bundle for $400 but cant find it now
-theMantis
-theMantis
Are the items you listed the exact places the leaks are coming from?
I assume you removed the fuel pump via the trunk panel to get the fuel out. If the fuel canister is'nt broken up top, no sense in replacing that. If the fuel filter is leaking, replace that or it could be the metal line has rusted away.
does it leak car on or all the time, what year car? what tank, metal or plastic.
the filler neck is about 50 off ebay. mine the vent tube rusted through and gas was leaking out the busted line when the tank was full.
I have several problems related to the fuel system and can't be sure what causes each specifically. I also can see 90% of the parts are original and almost rusted through. I have stopped the leak thus far with a putty, and now just need parts. I saw a deal for $400 where it came with everything i asked about in my original post
-theMantis
Check out rockauto. They carry a wide range of replacement parts.
