Thread: Squeaky belt
Results 1 to 6 of 6
  1. #1 Squeaky belt
    SE Level Member Drive XR7's Avatar
    Cleveland, OH
    I noticed the past few times I drove my GP there was lots of belt squeal.
    The belts are relatively new. I examined and found them still in great condition. I examined the pulleys and found that the supercharger belt on the crank pulley is 1 rib off. It's weird. Not sure how this could happen. I'll reseat the belt but am wondering how this could happen. The belt is tight, does not seem loose.
    Jason
    2001 Bronzemist Pontiac Grand Prix GTP - SOLD!
    2003 Sonic Blue SVT Mustang Cobra Convertible #2421 (1 of 340)
    2013 Ruby Red Ford Edge Limited EcoBoost
  2. #2 Re: Squeaky belt
    I always leave road debris in the back of my mind, stranger things have happened.
  3. #3 Re: Squeaky belt
    Cleveland, OH
    Twice in 2 weeks the belt has slipped a rib and started squeaking again. I noticed that the tensioner does seem to move in weird positions. Like when I turn it to remove the tension it's not a straight up movement. I feels like the whole tensioner assembly is shot.
    It looks like a torx nut holding the tensioner assembly on, and I probably stripped the hell out of it. Is this a torx nut or something else?
    Jason
  4. #4 Re: Squeaky belt
    sc tensioner is held on with a 13 mm nut, use a 12 pt socket to fit inside the hole where you see the stud end.
    id be looking at the two idler pulleys, if one of them has a play in it it could toss the belt.
  5. #5 Re: Squeaky belt
    Cleveland, OH
    I replaced the outside idler last year when it seized. I did not replace the second closer idler or tensioner.
    Will take a closer look, thanks.
    Jason
  6. #6 Re: Squeaky belt
    Cleveland, OH
    Replaced the tensioner assembly and smooth idler pulley, problem solved.
    Jason
  1. Really squeaky wheel
    By SomeDudeAtHome in forum General Grand Prix Discussion
    Last Post: 05-31-2014, 10:24 AM
  2. Squeaky belt/pulley/something? Come take a listen (video)
    By cloead in forum General Tech Discussion
    Last Post: 09-23-2012, 08:04 PM
  3. Squeaky squeaky
    By SDGTP99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-26-2011, 12:52 PM
  4. squeaky s/c belt
    By Joe m in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-12-2010, 02:53 PM
  5. Squeaky Belt, HELP!
    By Pokey in forum General Tech Discussion
    Last Post: 05-27-2008, 08:17 AM
