been having issues w/ my 99 gtp sensors . so i was reading a lot of forums on one it stated that a bad maf could cause your light for boost to the left of display would dim anyone heard of this ?
p0101 po121 tps and maf but also have abs light and tcs light today tried to hunt down abs the left sensor had dislodged from bracket and the 2 wires going to front wheel bearing sensor were bare tried separating the 2wires now the abs light stays on where before it would go off when restarted lots of other stuff going on
check the wires for damage to the maf and tps. they both could be bad. or bad wires to them.
also check fuse #21 marked ING, it powers the maf. if its blown change it, if it blows again you likely have bad wires to the maf or the upstream o2 sensor. the fuse is for both of them.
