Thread: Power steering fluid
Results 1 to 3 of 3
  1. #1 Power steering fluid
    SE Level Member themantis's Avatar
    Mar 2016
    How much fluid does a 99 GTP hold in it's power steering system? What's the normal operating temperature? Thanks
  2. #2 Re: Power steering fluid
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by themantis View Post
    2.2 quarts according to http://www.grandprixforums.net/threa...00-3-8L-Engine
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  3. #3 Re: Power steering fluid
    At a guess it's just over a 1-2 quarts of fluid if you had the system empty. The res tank is very small on these cars.
    Not sure if anyone would know the temps but well over 100-150ยบ as it's being pump at a good rate of speed and right next to the motor. We do have a built in cooler with how the lines are routed under the car, airflow does move across one of the lines.
  1. power steering fluid
    By tstaller2005 in forum General Tech Discussion
    Last Post: 05-03-2011, 10:34 AM
  2. Power Steering Fluid
    By Vlad0691 in forum General Tech Discussion
    Last Post: 11-12-2010, 08:48 PM
  3. Power Steering Fluid
    By FriboRage in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-22-2010, 01:26 AM
  4. What power steering fluid is best?
    By dl1027 in forum General Tech Discussion
    Last Post: 05-09-2010, 07:55 PM
  5. Power Steering fluid leak--Where?
    By jokyfo in forum General Tech Discussion
    Last Post: 10-06-2008, 05:17 AM
