Thread: No start no security light on
Results 1 to 4 of 4
  1. #1 No start no security light on
    Apr 2016
    Trosky mn
    Have a 02 gtp it started and died can get started with starting fluid put new pump in and new bcm had a blown passkey fuse but isn't blowing now I did the relearn and I'm getting to my end with it
  2. #2 Re: No start no security light on
    Apr 2016
    Trosky mn
    Well I will have to find a different place for help
  3. #3 Re: No start no security light on
    St. Louis
    Is the CEL on? Pull the vacuum line on the fuel pressure regulator and see if there is fuel in it. If so, replace the regulator. The only other thing that comes to mind is bypassing the fuel relay to put the pump into high speed mode if the fuel pump resistor has gone bad.
  4. #4 Re: No start no security light on
    Apr 2016
    Trosky mn
    Did the bypass didn't help and I pulled codes and all r for the egr witch was deleted
  1. Fml security wont start
    By Timing in forum Audio, Security & Visual Electronics
    Last Post: 10-09-2015, 08:08 PM
  2. Replies: 5
    Last Post: 10-04-2012, 02:40 PM
  3. security preventing start?
    By 98regal in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-19-2012, 12:50 PM
  4. PLEASE HELP! 02 GTP No Crank No Start with security light
    By CandyBlueta in forum General Tech Discussion
    Last Post: 02-08-2011, 12:43 PM
  5. Auto start or security system
    By sasquatch094 in forum General Tech Discussion
    Last Post: 12-09-2009, 10:16 AM
