Thread: Strange Brake Problem
Results 1 to 7 of 7
  1. #1 Strange Brake Problem
    Nov 2013
    Virginia Beach, Va
    2004 GP GT2 131k miles
    Hey guys, I have a strange problem With my brakes, but maybe not the brakes at all. Sometimes when I'm coming to a stop I can feel the ABS kick in with a "grinding" kind of feel to the brake pedal. The ABS light doesn't come on. This seems to only happen at a low stop stop like below 10mph. I have replaced the front pads and the master cylinder (Was going bad) and have good stopping power, no air in the lines, etc. Just this ABS type of thing once in a while. (Was doing this before the brake job) I checked today and there are no codes.
    So my thoughts are these:
    Wheel sensor going bad? (Front hubs replaced apx 6 months ago)
    Caliper locking up? (Didn't see any unusual wear on the pads)
    Rear brakes or sticking rear caliper? (Pads looking low/worn; not removed just eyeballed; haven't changed them in a while)
    EBCS starting to have problems? (I hope not; but no codes, although maybe my computer can't scan them?)
    Any suggestions? I hate to take it to a shop if it's something I can fix myself.
    Thanks guys.
  2. #2 Re: Strange Brake Problem
    Apr 2015
    Sounds like a sensor problem. Did you buy a good quality hub or a cheap one?
    Sent from my LGL41C using Tapatalk
  3. #3 Re: Strange Brake Problem
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    The ABS light does not come on when it's being engaged. It sounds like the wheel speed sensor is going bad. Or the ABS sensor in the hub. I'd check the wires running to both sensors and look for any damage.
  4. #4 Re: Strange Brake Problem
    GT Level Member Jnibbs24's Avatar
    Sep 2015
    Seattle
    Had this exact same issue in my Impala, replaced it with a couple hubs and every time I went to take the wheel off the wires were stripped out of the hub, was my front right, then put a timekin in there, same thing happened, I used the clip holder that's assigned and every time wires would be stripped, never did figure it out, the abs would only come on at really low speeds if I turned the wheel. All the way to the left. Front right hub was the issue, never figured it out n sold it with 215k miles on it, was done throwing money at it. Hope you have better luck!
  5. #5 Re: Strange Brake Problem
    GXP Level Member
    Mar 2015
    Tomball
    Quote Originally Posted by SubwayGuy View Post
    It does on 04+
  6. #6 Re: Strange Brake Problem
    Pennsylvania, USA
    My 2005 has never displayed any ABS icon while being engaged, only the TC on the DIC.
    For thine is the Cam, The Piston, and The Rod, Forever and ever (or until they break). Amen.
  7. #7 Re: Strange Brake Problem
    GXP Level Member
    Mar 2015
    Tomball
    My 05 has the couple of times it has engaged it comes up in the DIC.
    Jeff
  1. Strange problem......
    By Spike89 in forum Audio, Security & Visual Electronics
    Last Post: 12-20-2012, 12:22 AM
  2. STrange car problem. Need help quick
    By Logan541 in forum General W body
    Last Post: 10-17-2011, 05:46 PM
  3. Strange steering problem
    By tccmn in forum General Tech Discussion
    Last Post: 07-09-2011, 02:24 PM
  4. strange problem
    By LSXHP in forum General Tech Discussion
    Last Post: 01-15-2011, 01:35 AM
  5. very strange problem.
    By maniakmyke in forum General Tech Discussion
    Last Post: 03-04-2010, 04:45 AM
