Thread: Best way to put on roof rails
Results 1 to 10 of 10
  1. #1 Best way to put on roof rails
    GT Level Member Jnibbs24's Avatar
    Sep 2015
    Seattle
    Picked up some roof rails, what's the best way to adhere them. I was thinking 3m auto tape, but wondering if there's a better alternative? And no I'm not drilling holes...!
  2. #2 Re: Best way to put on roof rails
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    Get some double sided emblem tape and go along the entire bottom. Don't do a whole continous strip though, have some spaces in there.
    Make sure the part on the roof is clean too, otherwise it won't adhere well.
  3. #3 Re: Best way to put on roof rails
    Sep 2015
    Seattle
    Was wondering about that. Thanks. Also the flat end goes towards the front correct?
  4. #4 Re: Best way to put on roof rails
    Sep 2015
    Seattle
    Why do a few strips instead of one complete strip? Thank you
  5. #5 Re: Best way to put on roof rails
    Apr 2015
    Quote Originally Posted by Jnibbs24 View Post
    Because the roof rail is curved. If you can get a complete strip on there, go for it. But it might be difficult trying to bend it and make it follow the slight curve.
  6. #6 Re: Best way to put on roof rails
    Roof rails are labled Left and Right, you can't screw it up.
    One long strip of 3M tape is fine, both the rail and roof have a curve. Tape on the roof rail and drop it into place, that simple.
  7. #7 Re: Best way to put on roof rails
    Jan 2014
    AR
    I didn't find markings on mine but they fit best with the flat part at front, tucked under the seal. Grey 1/2" 3M attachment tape would be my first choice. I used black because thats what was on the shelf. After getting a good stick to the rail, peel back the ends of the tape liner a little and leave the ends hanging out where you can grab them. Position the rail and lightly stick the ends then pull out the tape liner once you're happy with the fit and press it all down hard. Next few times the car is warm on top, maybe mash them down again and wiggle to test for looseness as a re-check.
  8. #8 Re: Best way to put on roof rails
    SWPA
    This sh!t works wonders for helping 2 sided tape stick
    http://www.amazon.com/3M-Adhesion-Pr.../dp/B004TGJU2A
    I know a lot of auto body supply stores sell it if you want to pick it up locally.
  9. #9 Re: Best way to put on roof rails
    Jan 2014
    AR
    That stuff is indeed awesome. Probably overkill on roof rails since gravity works with them, but yeah. Hardest part on swapping mine over was getting all the old layers of tape and glue off. Thats very important, especially since any old stuff left on creates a wider gap around the rail.
  10. #10 Re: Best way to put on roof rails
    One BadAzz GT Dawgg Mirraco's Avatar
    Aug 2012
    Brainerd, MN
    You remove both the strips that where they sit at. The roof trim, then i just used some strong adhesive glue and it worked fine.
    01 GP GT navy blue 70K miles and counting, dd. 17" 05 gtp wheels, 35% tint, 05 heated leather, smoked led tail lights, k+n filter, zzp catted downpipe, 2004 exhaust, roof rails, reptile tune 08 G6 GT coupe 95k miles, racekar. 2 alpine type x 12", two alpine pdx 600 amps, pioneer 8000nex head unit (GPS ), heated leather, autostart.
  1. SOLD Roof Rails (photos added of rails)
    By 7801MonteMan in forum For Sale - Parts
    Last Post: 04-13-2014, 09:38 PM
  2. Roof rails
    By jayroca in forum Wanted To Buy - Parts
    Last Post: 02-21-2013, 03:13 AM
  3. Roof Rails? Yes.
    By nawarkk in forum Visual/Body Modifications
    Last Post: 04-18-2011, 11:22 AM
