2007 pontiac grand prix gxp with 5.3 LLeft front bearing is going bad. Any tips on doing the labor, like how labor intensive is it? Also what's a good brand for a good price? Car is bone stock
Sent from my XT1060 using Tapatalk
Check the "how to ". Section. Great write up there on how to replace. Pretty easy.
I followed a youtube video by Rich Pin on how to change a wheel bearing. https://www.youtube.com/watch?v=Y-TsTn-3ktk
It was easy to follow and the job is not hard if you have air tools. You will need an air impact and an air hammer. Good excuse to buy tools and I use both all the time. Yes you'll need the bigass 36mm socket, which can be expensive. You can order it on Amazon or they have them in stock at NAPA.
Just a big hammer will get most bearings off, just gotta know where to smack them to get them free if they are stuck.
I prefer the SKF brand over most, very good quality from napa.
I didn't follow any write-ups or how to's. I looked at it and figured it out. I used Moog bearings because it has a 3 year warranty and I could get them at my local Advance Auto for $100 after doing a discount code online and pick up in store.
Advance Auto has a loan-a-tool axle socket kit. You can get the nut off without an impact, I use a 3' crowbar between the lugs and the ground to keep the wheel from turning and a long 1/2" drive breaker bar or ratchet with pipe extension. If you take it off with a breaker bar and get a feel for the tightness, you should be able to re-tighten it close to the same tightness without a torque wrench. Overtightening the axle nut will bring the new hub bearing to an early death. Never re-install the axle nut with an impact. You are also not supposed to re-use the axle nut, but most folks do.
It's a straightforward job, caliper and rotor come off, remove axle nut, disconnect ABS wiring, remove 3 bolts that hold the hub bearing to the steering knuckle and it comes out.
Delco has a 5 year warranty on their hubs. Been running one for a year, so can't say if they are any better than the SKF's I've used that fail almost annualy. LOL
Here is my write-up (should be the same as the 04+): http://chrisb.users.superford.org/Gr...l_Bearing.html
Delco is a one year warranty.
http://www.amazon.com/ACDelco-FW293-...=ATVPDKIKX0DER
Axle nut should be 33mm.
I'd get it locally from the part store don't go cheap grab one with a 3 year warranty like Moog,skf/timken etc. I been running skf from Napa for a few months now so far so good
Sent from my KYOCERA-C6745 using Tapatalk
Well damn Amazon, I would have bought Delco if they are all 5 year. How much were those?
Not real sure but this isnt coming up in searches for that part number here. Is this a Canada thing lol?
The first two links are not AC Delco parts, and the last is Canadian ?
Yea, not sure . The second is clearly worded an GM, but states Aftermarket part in the description so it isnt Delco. The third link is Canadian, and is correct. I guess we are going to all have you buy our hubs from now on![]()
Delco is GM's "aftermarket" parts line. GM uses different part #'s, so that 2nd one is a Delco. Maybe I should start stock-piling these things. LOL
