Thread: Transmission problem
Results 1 to 6 of 6
  1. #1 Transmission problem
    SE Level Member r3dr4ng3r95's Avatar
    Jan 2016
    Not sure if I need an entire transmission but not sure what's wrong with the car. It revs really high in first, about 5000 rpms and accelerates really slow like its not catching. Once 2nd hits it's smooth sailing though. Until 4th gear and I try to make a pass again it seems like its not catching? Just revs really high.
    Sent from my HTCD100LVWPP using Tapatalk
  2. #2 Re: Transmission problem
    Just from your description, it sounds like it's slipping really bad.
    Won't be long before it won't move at all at this rate. You could suck out a quart of fluid and dump some lucas stop slip in for 10 bucks, but it might not even help you any.
  3. #3 Re: Transmission problem
    Jan 2016
    I have had a transmission leak. Could that have anything to do with it?
  4. #4 Re: Transmission problem
    GT Level Member WickedGoat's Avatar
    Dec 2014
    Missouri
    Quote Originally Posted by r3dr4ng3r95 View Post
    Yes, you need to check the fluid and fill as needed. No guarantee that it will fix what is wrong with the transmission but you need to take care of the simple stuff first and see what happens. If you end up needing a rebuild, bank on at least $1700 for a complete rebuild with a new converter. Find a good shop that knows this trans and its factory weaknesses and you should be good to go for a good while, provided you aren't constantly spinning the tires and thrashing on it.
    2014 Chevy Impala LTZ Limited -- Silver/Black, Grand Prix replacement
    2004 Pontiac GTO -- my garage queen
    2004 GMC Yukon SLT -- wife's daily driver
  5. #5 Re: Transmission problem
    Jan 2016
    So an update on this issue: I don't need an entire rebuild. I took the time to take out the transmission the last few weeks (pain in the ass to do with limited and borrowed tools, but it is getting done) somehow one of the transmission bands snapped and the broken piece was just sitting in my transmission pan. So I'm going to get the band to replace it and gasket set to put the beast back together.
  6. #6 Re: Transmission problem
    Jan 2016
  1. transmission problem
    By ericg1181 in forum General Tech Discussion
    Last Post: 09-07-2012, 09:13 PM
  2. Problem with transmission NO REVERSE...Any suggestions of problem
    By newmy1d in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-28-2012, 11:36 AM
  3. Transmission Problem
    By rubent in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-14-2011, 10:34 AM
  4. Transmission Problem
    By cbeach in forum Introductions/Noob Questions
    Last Post: 12-30-2010, 08:23 PM
  5. Transmission problem
    By lhssnowman in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-15-2009, 03:38 PM
