Thread: Swaping engine and trans from top ( first timer)
Page 23 of 33 FirstFirst ... 132122232425 ... LastLast
Results 441 to 460 of 645
  1. #441 Re: Swaping engine and trans from top ( first timer)
    Apr 2011
    North Los Angeles
    I was hoping there would be a bracket there that would explain the engine shake. A friend of mine who has a code reader wont be back till mon. Im wondering if i should go to hf and pick up the 40 dollar one.
  2. #442 Re: Swaping engine and trans from top ( first timer)
    you check the trans fluid yet while it running? fill it up if needed? get that done and drive it to the parts store, autozone scans for free.
  3. #443 Re: Swaping engine and trans from top ( first timer)
    Enfield, CT
    A bracket does go there. I have one on my 06.
  4. #444 Re: Swaping engine and trans from top ( first timer)
    you got a miss fire causing the engine to shake, not the bracket that kyle is now saying is not there. more stuff on the floor to look for lol
  5. #445 Re: Swaping engine and trans from top ( first timer)
    Apr 2011
    North Los Angeles
    what do you mean by misfire Scotty? how can i fix this i made sure wires were in the right order and they weren't damaged as far as i could tell.
    Heres another symptom the car shakes more when i give it gas but then smooths out after about 1000 rpm
    Also i got gallon of antifreeze 50/50, about how much more will i need?
  6. #446 Re: Swaping engine and trans from top ( first timer)
    Apr 2011
    North Los Angeles
    Quote Originally Posted by HighOctaneRacing View Post
    thanks for the input ill be looking into getting one.I know the older engine did not have one either, the bolt holes were covered in muck. Where does this bracket connect to on yours, can you take a pic?
  7. #447 Re: Swaping engine and trans from top ( first timer)
    one more, then some water to top off.
    the way its stumbling is a misfire. two crossed plug wires will do that, its easy to fvck them up, so go check once more.
    it could be a injector thats not firing. you can swap the fuel rail and injectors from your old engine, cause we know they worked.
    but the code will tell us exactly whats going one.
  8. #448 Re: Swaping engine and trans from top ( first timer)
    Enfield, CT
    Bolts to the oil pan and connects to the transmission bellhousing. I have a pic. Give me a few minutes to post it up.
    Sent from my LG G3
  9. #449 Re: Swaping engine and trans from top ( first timer)
    he has that bracket, this is the two holes on the belt side of the oil pan.
  10. #450 Re: Swaping engine and trans from top ( first timer)
    Apr 2011
    North Los Angeles
    ok gota get more coolant then im driving the shakey beaut to autozone
    nvm..they dont read codes here in ca, we've got all the best laws
  11. #451 Re: Swaping engine and trans from top ( first timer)
    got the tranny filled up already? dont drive it till its to the cold line on the stick.
  12. #452 Re: Swaping engine and trans from top ( first timer)
    Enfield, CT
    Sent from my LG G3
  13. #453 Re: Swaping engine and trans from top ( first timer)
    kyle, what about the other side, left side two holes?
  14. #454 Re: Swaping engine and trans from top ( first timer)
    Maybe the motor came from buick with the 4 engine mounts.
  15. #455 Re: Swaping engine and trans from top ( first timer)
    Apr 2011
    North Los Angeles
    Sent from my LG G3
    Isn't that the right side if you're standing in front of car? I have those on the bottom right.
  16. #456 Re: Swaping engine and trans from top ( first timer)
    Apr 2011
    North Los Angeles
    Tranny is full I put eight earlier just added two more.
  17. #457 Re: Swaping engine and trans from top ( first timer)
    Enfield, CT
    Yea
    Sent from my LG G3
  18. #458 Re: Swaping engine and trans from top ( first timer)
    Enfield, CT
    Oops. Didn't see your earlier post lol. Those 2 bolt holes are for a different model car. My bad lol
    Sent from my LG G3
  19. #459 Re: Swaping engine and trans from top ( first timer)
    Apr 2011
    North Los Angeles
    Sent from my LG G3
    which two bolt holes? th ones on the bottom left or right and corresponding to which car? i have a pair of holes on the bottom left and right. the right holds a bracket the left is??
  20. #460 Re: Swaping engine and trans from top ( first timer)
    Apr 2011
    North Los Angeles
    i trippled check the wires too and they are right. I guess ill have to spend on a code reader from hf.
  1. 97 Grand Prix 3.8 Supercharged engine at local junk yard. Worth saving?
    By sgtmac in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-28-2015, 08:38 PM
  2. Replies: 2
    Last Post: 09-30-2013, 11:34 AM
  3. Just bought an '05 with 100K that needs a new engine
    By woodoggie in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-27-2012, 11:35 AM
  4. wrecking 04 grand prix gt- alberta
    By turbo dave in forum Canada
    Last Post: 10-29-2011, 12:00 PM
  5. good salvage yard?
    By nitrostang21 in forum Off Topic Discussion
    Last Post: 09-13-2010, 04:53 PM
