Thread: installed leather seats and seatheat panel still no heat!
Results 1 to 12 of 12
  1. #1 installed leather seats and seatheat panel still no heat!
    Jan 2016
    spicer mn
    a while back i installed leather seats into my 2007 base grand prix. everything out of grand prix everything factory gm. all the plug ins under the seat plugged into factory wiring nothing left unplugged! i also bought the heater panel with the seat heat buttons. when i push the button the light comes on for a second and then goes out. passenger side same thing! where do i start? does the bcm need to be programmed? need more parts? the fuse is in there so cant be that!
  2. #2 Re: installed leather seats and seatheat panel still no heat!
    Pennsylvania, USA
    I do believe you need to have the BCM reprogrammed at a dealership. I'd imagine it would cost around $50 depending on the labor rate.
    For thine is the Cam, The Piston, and The Rod, Forever and ever (or until they break). Amen.
  3. #3 Re: installed leather seats and seatheat panel still no heat!
    Jan 2016
    spicer mn
    Some dealership told me that the bcm cannot be reprogrammed! Whether this is true or not I do not know! Every dealer has told me something different. I even asked them if they could just call gm tech and they could not call them to ask. That's sounds like bull!/!#
  4. #4 Re: installed leather seats and seatheat panel still no heat!
    GTP Level Member Burbman's Avatar
    Dec 2008
    ****'s Creek
    GM uses what they call RPO codes, stands for Regular Production Option. If you look in either the glovebox or on the inside of the trunk lid you will see a sticker with a series of 3 character alphanumeric codes. These identify the options that the car was built with, and also get programmed into the BCM to enable switches and functions.
    Many times when the dealer says they cant do it they just dont want to mess with it. Some of the guys that do custom tunes do BCMs as well.
    You mihht also check the fuse listing in the owners manual, you say the fuse is there but you may be missing a relay. Most of these high current accessories use a relay activated by the switch to power the accessory. If your car wasnt built with heated seats it may not have the relay installed on the fuse block.
    Sent from my SPH-L720 using Tapatalk
    2002 GTP Coupe, PSE supercharger ported with 3.4 pulley, Wizaired CAI, ZZP tune, AL 104's, front Plog, 3" DP, u-bend gone, hi-flo cat, W-Body tubular trailing and lateral arms, GMPP sway bars, Vogtland springs, 245/45-18 Michelin Pilot Sport AS/3 on 18x8 wheels, 42mm offset, Dual Aeroforce interceptor gauges on A-pillar pod
  5. #5 Re: installed leather seats and seatheat panel still no heat!
    Jan 2016
    spicer mn
    My girlfriend has a 2008 grand prix that came with heated seats and I have all of the same relays.
  6. #6 Re: installed leather seats and seatheat panel still no heat!
    Dec 2008
    ****'s Creek
    It was just a thought
  7. #7 Re: installed leather seats and seatheat panel still no heat!
    Aug 2015
    Virginia
    I'm looking to do the same thing in my 05 GP GT from an 06 donor car. Did you get it to work?
  8. #8 Re: installed leather seats and seatheat panel still no heat!
    Jan 2016
    spicer mn
    Going to dealer on Tuesday will post results hopefully good! They are also checking on why the hvac system does not come on when I use the remote start. It does not come on even if the engine is warm and I do not have automatic climate control just regular fan manual heat adjust
  9. #9 Re: installed leather seats and seatheat panel still no heat!
    Jan 2016
    spicer mn
    Dealer said they cannot program bcm
  10. #10 Re: installed leather seats and seatheat panel still no heat!
    Aug 2015
    Virginia
    Well that sucks
  11. #11 Re: installed leather seats and seatheat panel still no heat!
    GTP Level Member 99GT2dr's Avatar
    Cibolo, TX
    Am I missing something, or is there a reason you don't just run the switch to your own relay to power the seat heater? You don't have to use the factory wiring.
    '11 Suburban LTZ
    '99 SSEi
    '99 GT
    '09 G8 GT
  12. #12 Re: installed leather seats and seatheat panel still no heat!
    Jan 2016
    spicer mn
    What is the best way to hard wire these seats in?
  1. 04+ leather seats
    By redgtp97 in forum Wanted To Buy - Parts
    Last Post: 05-03-2013, 11:57 PM
  2. Leather Seats
    By Tremayne0126 in forum Visual/Body Modifications
    Last Post: 09-03-2011, 08:23 PM
