Thread: Avt-852 (dhp)
Results 1 to 3 of 3
  1. #1 Avt-852 (dhp)
    Apr 2015
    Lincoln NE
    I talked to Matt at AVT and he has the equipment new for the DHP software. However he asked if I wanted the L model, which includes wideband functions, or just the default E version. Have any of you guys ordered from him? If so what one did you pick up and how did it work?
  2. #2 Re: Avt-852 (dhp)
    hangover park IL
    the wideband functions is the analog to digital converter that is the small green connector on the side of the box it allows for additional 0 to 5 volts inputs for data logging. you will want that if you are doing this for making reliable decent power
    ~James~ Psychotic Gearhead
  3. #3 Re: Avt-852 (dhp)
    GXP Level Member
    Mar 2015
    Tomball
    I have the 852 L as well I like it and for the additional 3 inputs to log anything I want to that is 0-5V so if you wanted to run temp sensors for IC or monitor Crank case pressure it's pretty easy. I haven't used them yet, but they are easy to select and connect to the DHP software.
    Jeff
